Author Topic: Air Temp at Register  (Read 10920 times)
ptt811
  • OWF Brand: Wood Boiler USA...LLC.
  • OWF Model: Wood Boiler Standard
« on: November 25, 2012, 06:53:32 AM »
Just wondering what you guys are getting for an air temp reading at your register. I have two heat exchangers/Furnaces...2 separate duct runs, ( 2 totaly seperate systems ) with the first one being " T d" into the line with ball Valves to adjust the flow to the first exchanger. I am trying to Balance both units and about the best I can get is 95 degrees?(Air Temperature) Boiler temp is set at 170....with a 10 degree diff...Boiler is set at about 80 feet From the house and I use a 3 speed Taco pump set on the second speed.
 Doesn't work to bad but the original house take a lot longer to reach temp than the Addition does, But the addition is about 1/2 the size of the original house.
Just wondering....
Wood Boiler USA...
1 st. Year with OWB
West, Central...INDIANA
jerkash
  • OWF Brand: Legend
Re: Air Temp at Register
« Reply #1 on: November 25, 2012, 07:16:03 AM »
My boiler is set at 170 - 180 and is 125 feet away from my house.  I get 110 temp reading at my registers
garz
  • OWF Brand: Central
  • OWF Model: CL-17
« Reply #2 on: November 25, 2012, 08:25:21 AM »
With incoming water at 175.6  I have 123 degrees at register.
Central CL-17 that's old enough to vote
Stihl MS362, 028, 192T
Husky 286XP
Swisher 30T splitter
IH 235 diesel tractor
Paris, IL
« Reply #3 on: November 25, 2012, 11:20:05 AM »
Have you tried with the pump on high? Is it a 00R pump?
ptt811
« Reply #4 on: November 25, 2012, 03:38:26 PM »
Yes it is an 00R Taco pump...  Last winter was my first year and I ran it on LOW all year, but we had a warm winter here in Indiana last winter.  My house stays warm but the furnace will run for about 20 minutes to raise it 2 degrees. But the addition furnace will run for about 5 minutes to do the same work.
I always thought the faster the pump ran the less heat it will pull out of the water..is this night right ?
Wood Boiler USA...
1 st. Year with OWB
« Reply #5 on: November 25, 2012, 09:04:50 PM »
No, that is opposite. If you run it faster you will get more heat.
ptt811
« Reply #6 on: November 26, 2012, 03:41:16 AM »
So do you think I need a bigger pump....  How much GPH or GPM  Should I be looking for ?    The boiler I have runs water through the door to cool it... wouldn't take nothing to remove a hose and fill a 5 gallon bucket and time it ?
Wood Boiler USA...
1 st. Year with OWB
jb1978
  • OWF Model: Hoss 300 HE
« Reply #7 on: November 27, 2012, 07:50:00 PM »
Im getting 150-155 at my register. Aquastat at 175 with 5 degree diff.
