Author Topic: OWB to heat Dream maker eclipse 110v  (Read 15004 times)
Drivebymashing
  • OWF Brand: Earth Outdoor
  • OWF Model: 305 Bear Cub
Re: OWB to heat Dream maker eclipse 110v
« Reply #15 on: December 28, 2012, 01:27:11 PM »
Ok this will be my whole setup  What temp is sch 40 pvc rated for?  Yeah my existing pump on my boiler will run 160 degree water through the tube exchanger all the time  .IS that what you mean?Im still learning at this.Thanks for the help
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
1971 Deuce and a half 10x10
Drivebymashing
« Reply #16 on: December 31, 2012, 10:58:17 AM »
OK i drained my tub and looked everything good one more time.I notice they make smaller single speed motors that will bolt to my wet end where the fittings are.Now im thinking i could put a smaller motor and add my heat exchanger on the discharge side of pump and still use hottub controls.Hmmmm maybe i think too much.
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
Drivebymashing
« Reply #17 on: January 01, 2013, 03:06:06 PM »
Yeah i think ill try it with pump thats on there it wont save me much money if i use the factory pump its a single speed and runs when either heating or jets are running. Its a 12 amp 1.5 hp motor.Cant i use the factory t stat and controls just T in the heat exchanger on discharge side?ITs 1100 watts running  A 3/4 hp motor that fits the wet end is supposedly 299 watts.Which is more than enough i think to run jets  i never turn them all the way up anyways.Just have water running through heat exchanger all the time like on my drinking water and whenever pump kicks on for hottub it will pump the heated water through?
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
Drivebymashing
« Reply #18 on: January 02, 2013, 04:12:11 AM »
Good point it has gotten up to 105 before while filtering  its set at 102  with a 1 degree diff.I will try and see what happens .I cant believe how helpful this website has been  .Thanks!!
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
Drivebymashing
« Reply #19 on: January 12, 2013, 03:02:23 PM »
OK so you were right.My water temp after tube exhanger install was 162 degrees just a tad warm for a hottub.Im going to do the zone valve deal .And use factory motor for a while to try it.The proble i have now is i cant find any info on the pipe thread on the motor
it says 2 inch
2 inch pvc is wrong thread size
2 inch drain like for a sink is wrong
2 inch pvc compression is wrong also
So as  soon as i can find the right thread size adapters ill be in good shape
Thanks!
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
« Reply #20 on: January 12, 2013, 09:13:04 PM »
How did you end up plumbing it? Like any of the pics in this thread?
Drivebymashing
« Reply #21 on: January 13, 2013, 07:09:59 PM »
The only thing i have plumbed in is the tube exchanger in line with my return to boiler.I removed the pump hoping to extend the threaded end out to mount the factory pump outside the tub in a box .Then hook in my heat exchanger.Id like to leave the threaded ends so if i ever want to sell the hottub i just mount the pump back inside it.In other words i need adapters i can screw into factory threads to extend the lines out of it.Im gonna use the three way zone valve with a ranco controller and  use factory hottub controls.
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
Drivebymashing
« Reply #22 on: February 01, 2013, 08:49:54 AM »
Ok finally found some 1.5 buttress to 1.5 inch mpt adapters they fit perfect.So i dont have to cut into factory tub plumbing.My tub uses a friction ring heater so i can leave it in place and just add my tube exchanger. I hope to have this thing going soon im trying to find some wiring diagrams for the 24 volt side of the ranco to three way zone valve.Thanks   ITs been down a month.Today its 15 degrees with a zero degree wind chill.Brrr    76 degrees inside i also have the flu....
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
Drivebymashing
« Reply #23 on: February 01, 2013, 06:53:11 PM »
It took four different tries to find it.I did the electric part with the ranco and transformer ill hook the valve up whenever it warms up some.Just hooking up five wires and turning three screws about killed me flu is roughhh.Im looking forward to having a 85 dollar electric bill.With a hottub and 76 degrees in the house when its below freezing outside.
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
Drivebymashing
« Reply #24 on: February 20, 2013, 07:05:44 PM »
Alright two months later it is all together.Ill take pictures and test it this weekend.Cant wait to get it going again the plumbing looks interesting but i think it will work.
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
