Author Topic: Pics of ML42 install.  (Read 12273 times)
MrDan27611
  • OWF Model: ML42
« on: December 14, 2012, 07:12:34 PM »
So I've asked enough questions on here. I figured I'd post pics of the install now that it's all done. I'm trying to post photo's for the first time, so forgive me if I mess this up. I tried posting the pics inline. I'm sorry, I couldn't get it to work so I posted the link to the pics.
The old boiler, after removal.
http://www.flickr.com/photos/24069905@N02/8274029800/#
The hole where the old boiler has just left.
http://www.flickr.com/photos/24069905@N02/8272963299/#
The new ML42 after we got it onto the concrete (that wasn't easy!)
http://www.flickr.com/photos/24069905@N02/8272963413/#
I was height limited on a new boiler. We had P&M make the boiler without legs, no fill tube, no lift eye, no cladding, no insulation, etc. Here is how much clearance we had. This is with the boiler sitting flat on the concrete.
http://www.flickr.com/photos/24069905@N02/8274031386/#
« Last Edit: December 16, 2012, 12:22:29 PM by MrDan27611 »
Don't go around saying the world owes you a living. The world owes you nothing. It was here first.
Mark Twain
MrDan27611
  • OWF Model: ML42
Re: Pics of ML42 install.
« Reply #1 on: December 14, 2012, 07:23:08 PM »
Unfortunately I had a bad weld on the boiler that leaked on the first fill. Fortunately P&M accepted a warranty on it with no hassle. I had a buddy who welded it right away so no downtime.
http://www.flickr.com/photos/24069905@N02/8272963893/#in/set-72157631846383780/
Closer view of the weld and the leak.
http://www.flickr.com/photos/24069905@N02/8272964113/#in/set-72157631846383780/
Boiler in and plumbed, stack cut into roof and tied in.
http://www.flickr.com/photos/24069905@N02/8272964419/#in/set-72157631846383780/
I went with spray on insulation for the boiler. It made a mess but it sure does insulate well.
http://www.flickr.com/photos/24069905@N02/8274032582/#in/set-72157631846383780/
We added our own cladding to the front of the boiler to tie it in and give a finished look. This is the bottom half already on.
http://www.flickr.com/photos/24069905@N02/8274032704/#in/set-72157631846383780/
The rear of the boiler, all insulated.
http://www.flickr.com/photos/24069905@N02/8272965435/#in/set-72157631846383780/
The ML42 up and running.
http://www.flickr.com/photos/24069905@N02/8274033420/#in/set-72157631846383780/
First fire. I went from 60 degree water to 180 in 3 hours with it 1/3 full of wood.
http://www.flickr.com/photos/24069905@N02/8274033590/#in/set-72157631846383780/
Mark Twain
dwneast77
    • HeatherWood Gardens
« Reply #2 on: December 14, 2012, 07:49:14 PM »
Great looking setup!!  Nice pics!!
Eastern Maine (near Calais)
Central Boiler E-2300
Wood Doctor HE10000
Stihl 290 Farmboss
Craftsman 27 ton Splitter
JD 870 Tractor
AirForcePOL
  • OWF Model: G400
« Reply #3 on: December 15, 2012, 06:52:52 AM »
Nice setup!  I like how you have it located in that building.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
franky1
« Reply #4 on: December 17, 2012, 11:51:00 AM »
looks good
let us know how it compares with ur old furnace
SOHIO
  • OWF Model: ML36
  • Steve in OHIO
« Reply #5 on: December 21, 2012, 09:36:32 PM »
Would like to know more about the solar panels, is that for summer DHW? Power for the Boiler?
Very nice set up you have there!
Husqvarna 460 $325 Craigslist brand new Sears store closing buyout
Husqvarna 455 $199 Sears deal
Husqvarna 435 $142 VMinnovations refurb
Poulan 2150
Homelite
johnybcold
  • OWF Model: Classic E1400
« Reply #6 on: December 22, 2012, 06:52:51 AM »
I like some points with the indoor units, my next house might get one
old truck
old craftsman chain saw
Polaris Sportsman 500HO
MrDan27611
  • OWF Model: ML42
« Reply #7 on: December 22, 2012, 04:11:43 PM »
The solar panels are for heating the water during the summer. That gives me DHW without firing the boiler, at least in theory. I'm still working out the reality.
Mark Twain
MrDan27611
  • OWF Model: ML42
« Reply #8 on: December 22, 2012, 04:17:17 PM »
looks good
A compare vs. my old boiler. I had about 110,000 btu of fire capacity with the old one. The Ml42 has about 300k btu. While my old one would be working hard, the new one is loafing.
I'd retrofitted my Aqua 2 with Johnson controls, however I had an issue with creosote clogging up my fan so I was unable to run mine hot enough to idle. Now I can stoke the boiler and leave it to idle. My temperature's are maintained at a much more consistent level.
The fire door is much larger and thanks to the legs I welded on, much higher. It's MUCH easier to load the new boiler.
The aqua 2, when stoking, would still draft properly so I got very little smoke in the face. The new boiler rolls smoke out the door no matter what I do. I smell like smoke quite a bit more often now.
If I could have made my old boiler idle, it would have done a fine job for me. Since I couldn't successfully idle, the ML42 is kicking the old boiler behind.
Mark Twain
SOHIO
  • OWF Model: ML36
  • Steve in OHIO
« Reply #9 on: December 22, 2012, 10:25:09 PM »
Do you heat the boiler water with the solar panels?
Can you explain your setup?
Poulan 2150
Homelite
MrDan27611
  • OWF Model: ML42
« Reply #10 on: December 23, 2012, 02:36:15 PM »
Yes, the solar panels heat the boiler water through a DHW heat exchanger. Since none of my tie in from the house goes to the boiler itself, you heat the boiler water, then the normal heat loop takes the hot water to the house where all the heat exchanger magic happens in the 500 gallon storage tank, and the mass of copper pipes take things to the proper place.
Mark Twain
