Author Topic: Using existing Honey TH5000 thermostat  (Read 4580 times)
robash9608
  • OWF Model: Shop Built
« on: December 31, 2012, 08:56:35 PM »
I have a new 4 ton Heil DX 1500 split unit heat pump. I want to use the heat pump as a backup for my OWB. I've heard of people unhooking the electric heat strips and putting the thermostat on emergency heat to only use the thermostat to control the blower. Can I use this Thermostat for this application?
The link below contains the  thermostat that I'm using, its the TH5220D model.
http://cache.air-n-water.com/manuals/honeywell-th5220d1029.pdf
Husqvarna 272xp
Husqvarna 55 rancher
Stihl 261
Homemade 30 ton splitter
Shop Built Furnace
Re: Using existing Honey TH5000 thermostat
« Reply #1 on: January 01, 2013, 04:30:56 PM »
I wouldn't do it like that...  You can install another thermostat right by your exsisting one that will just turn the fan on, u use jumper wires and it literally takes 5 minutes.
