Pages: 1 [2] 3 4
Author Topic: I'm seeing snow melting above my lines.  (Read 44076 times)
Re: I'm seeing snow melting above my lines.
« Reply #15 on: January 07, 2013, 04:59:20 PM »
i have some snow melt but I do not think I am losing heat from my pipes but through the pipe acting as a chimney. I sprayed foam into the pipe but need to do a better job Wood consumption does not seem excess. My other line with the same pipe to another building does not melt at all.
Acting as a chimney?  Huh
If your melting snow the heat is coming from the lines, I doubt you'd pull enough air put to amount to anything, stick a rag in it and see
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #16 on: January 07, 2013, 05:26:23 PM »
Is it possible to just replace and splice the insulated line just inside the house? I have about 40 feet of run inside that I don't see any reason to replace. If need be.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
« Reply #17 on: January 07, 2013, 05:41:54 PM »
Yes of course....  How many feet of underground do you actually need?
yotehunter66
  • OWF Model: 4400
« Reply #18 on: January 07, 2013, 06:08:54 PM »
I'll have to measure it to be sure but my stove is only about 40-50 ft from my house.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
netwerx-r-us
  • OWF Model: Hoss 400HE
    • Netwerx-R-Us
« Reply #19 on: January 07, 2013, 06:29:44 PM »
I'm no expert nor do I claim to be but if you think there is a problem with your underground pipes you need to know for sure before you buy new and dig up and replace , How you ask? , simple, buy 4  1 inch T's, buy 4 of these  http://www.blueridgecompany.com/radiant/hydronic/660/pasco-temperature-gauge and put them in your line with the T's leaving the OWB , coming into your house and one in the return coming back to your OWB  and you will know what kind of heat loss you have for sure instead of guessing, WillieG referenced this in the 3rd post
just makes sense to me , less than 50 dollars and you will know for sure
« Last Edit: January 07, 2013, 06:35:02 PM by netwerx-r-us »
Netwerx-R-Us
http://netwerx-r-us.com
Echo 440
Honda Rancher 400
Kubota ZD326
« Reply #20 on: January 07, 2013, 06:45:15 PM »
If he's melting more snow every year that's a pretty good sign...
I was really curious if he'd noticed an increase in wood use as well....
tbone
  • OWF Brand: Heatmor
« Reply #21 on: January 08, 2013, 08:26:34 AM »
I use to melt snow....but not anymore.  I replaced my lines over the summer.  I still have snow in my yard from 2 weeks ago...and no indication of were my lines are running.  But most importantly I'm using less wood.
Stihl pro 360
Honda 27 ton splitter
Ford 350 with hoist
« Reply #22 on: January 08, 2013, 02:39:14 PM »
if we were to say that you were losing heat the whole length of your pipe (50 feet) we couls also say that a 3/4 inch slant fin baseboard heater gives of (at 170 degrees) about 500 btu per foot (your underground lines would be at least that if not more if they are water logged) so 50 feet times 500 btu would be around 25,000 btu per hour that would likely heat a small home. i dont assume you are losing that much heat as the lines are not likely all water logged but i am just posting this so you will know what the potential loss per foot of compromised pipe might be  (and that is in the area of 500 btu per foot)
yotehunter66
  • OWF Model: 4400
« Reply #23 on: January 08, 2013, 04:05:00 PM »
Well mine has no snow of frost the entire length from my stove to where it comes out of the ground and enters the house. I'll get a infrared and check it.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
603doug
« Reply #24 on: January 08, 2013, 04:52:06 PM »
I should have explained I have 2 sets of lines running in my trench(stove and hot tub),plus i do not have any temp drop from the stove. Only melt is at the ends about 10 ft
gandgracing
« Reply #25 on: January 25, 2013, 01:55:33 PM »
Got a little snow last night and you can just see the snow melting.
johnybcold
  • OWF Model: Classic E1400
« Reply #26 on: January 25, 2013, 02:21:47 PM »
I think it depends on the outside temp last year I never saw snow melt over my pipe but a few weeks ago it did made a perfect path but it was around freezing, this week temps 5-20 degrees and no melting, I have the CB insulated pex
old truck
old craftsman chain saw
Polaris Sportsman 500HO
johnybcold
« Reply #27 on: January 25, 2013, 02:22:27 PM »
old truck
« Reply #28 on: January 25, 2013, 02:59:00 PM »
Melting the snow is the signs of an obvious problem.....  Willie has shown some calculations on here before that will baffle you at how much heat you could be losing.  I've got just your basic 3 wrap on mine, it's about 18-24" deep and I see no snow melt
« Reply #29 on: January 25, 2013, 03:29:55 PM »
i would say it's time to investigate..water temp leaving teh OWB and water temp entering the house- if possable measure with a thermometer by draining al ittle water at the boiler and then soing the same thing in the house if you can
if you can get an accurate temp difference and can figure out your GPM running in the line you can then equate  your heat loss fairly close
Pages: 1 [2] 3 4
