Author Topic: Wood Gasification Boiler Build  (Read 87565 times)
Wm Fritz
Re: Wood Gasification Boiler Build
« Reply #15 on: March 12, 2013, 09:43:17 AM »
Looking forward to your build Z.
Bookmarking this thread.  :thumbup:
zimmer988
« Reply #16 on: January 27, 2014, 12:21:39 PM »
Well I finally got started on the fabrication of my boiler!
You can check out some of the pictures here: https://www.dropbox.com/sh/h4lbsxbz8g5ckco/snOXOEeL1E
« Reply #17 on: January 27, 2014, 01:16:04 PM »
That thing is a BEAST. Can't wait to see and hear about yours too.
binfordw
« Reply #18 on: January 27, 2014, 01:45:50 PM »
Alright, glad to see a current build thread!
Looking good, nice pics.  I would be interested in a better angle of how you laid the firebrick in the secondary.  It looks like your nozzle is in the middle of the burn chamber?  Does the firebrick route the gases forward first- or is it just open to go back towards the heat exchangers?  I'd also like to know what firebrick you used,  I'm trying to lay my secondary out in CAD with the brick, to minimize cutting.
renoman
  • OWF Brand: ShopBuilt
  • OWF Model: One Hot Gasser
« Reply #19 on: January 27, 2014, 08:10:33 PM »
Nice build!! Looks awesome and looks like you have the equipment to do it too!
Brings back memories of my build but mine didn't turn out that nice.
zimmer988
« Reply #20 on: January 28, 2014, 09:40:07 AM »
Actually, I will be using refractory cement instead of firebricks.  I have not put the cement in the boiler yet though.  That will be done once I get the water jacket on and tested for leaks.  I may lay some firebricks under the nozzle so that they can be easily replaced.
« Reply #21 on: January 28, 2014, 11:10:17 AM »
I have heard that the refractory cement is really hard to work with and expensive. Do you have any experience with it or just going to give it a go? Personally I always like to give anything a go and see what I can make happen.
zimmer988
« Reply #22 on: January 29, 2014, 09:02:14 AM »
I have never personally used it but I have some connections to help us out.
zimmer988
« Reply #23 on: March 06, 2014, 03:34:45 PM »
I added a few more pictures to the Dropbox of our build.  We decided at the last minute before we put the top on to add a pipe for possible future burning of wood chips.  We installed a flapper on the bottom of the pipe that will be counterbalanced closed and will also build and install a rotary valve on the top side of the pipe to meter in chips fed from an auger.  That part will take some more designing at a later date.  We thought we should do it now to make it easier down the road.
You can check out the pictures here: https://www.dropbox.com/sh/h4lbsxbz8g5ckco/snOXOEeL1E
« Reply #24 on: March 07, 2014, 08:04:09 AM »
That is some IMPRESSIVE S***. Good job!
binfordw
« Reply #25 on: June 29, 2014, 07:44:44 PM »
I see you have 3 air channels into firebox, whats the purpose of the top inlet?  Most I've seen use air midway or even lower, and air at the nozzle.  I guess its better to have it and not need it than need it and not have it?
« Reply #26 on: July 02, 2014, 07:49:23 PM »
You guys that can design, weld, fabricate so well are awesome!  Super nice job.  :)
zimmer988
« Reply #27 on: February 13, 2023, 09:01:10 AM »
I finally got this boiler installed and have it heating my house and a 45x60 shop with floor heat.  It works great!
https://photos.app.goo.gl/YY3SUF3RA7HLLSeeA
zimmer988
« Reply #28 on: February 13, 2023, 09:08:38 AM »
I am also measuring the temperatures with a Click PLC and some ESP8266 flashed with Tasmota.  I have the readings going to my Home Assistant instance and logging the data with InfluxDB and Grafana.
