Author Topic: Insulating my underground piping.  (Read 13754 times)
dave_dj1
Re: Insulating my underground piping.
« Reply #15 on: January 24, 2013, 05:44:14 PM »
I'm kind of surprised no one told him to check his temps on the lines at the boiler and in the house. That would be a sure sign if you are losing a lot of heat in the pipe. If the run is only 15' I wouldn't think there would be much loss unless they are going through some water in the big pipe.
Also if only a 15' run I would go to my nearest Lowes or HD and buy me some 1" pipe and start there.
« Reply #16 on: January 24, 2013, 05:52:08 PM »
15' of un-insulated would lose quite a bit of btu's.
Every little bit counts, if you gain a few here, a few there, and get it all as good as you can, you can definitely improve things
« Reply #17 on: January 24, 2013, 06:02:01 PM »
He's actually very lucky, he can remove the cover on the regular insulated pipe and slide the pex and insulated part through his exsisting pipe.
DaveWertz
  • OWF Model: H4
« Reply #18 on: January 24, 2013, 07:10:50 PM »
Well I went and bought some polyurathane pipe wrap (glorified foam) and wrapped my copper pipes. I let things go for about 3hrs and noticed a 4 degree difference in my house!!! Don't know if I got lucky or what but my blower hasnt kicked on for awhile so it hasnt called for heat in a bit either. Think I am going to try to insulate the PEX next. I think one of my major problems is there is not enough registers in my home  I.E. One per room. Doesn't seem if I went to 1" pipe that it would help much because of the lack of baseboard registers. Just my guess though.
2001 F150 7700 series
09 Harley Superglide custom
Stihl Farmboss 290
« Reply #19 on: January 24, 2013, 07:29:35 PM »
See, every little bit counts.  The underground will be another step
But 1" will def move far more btu's
Twice as much water will flow through a 1" line vs 3/4".. Or there about, it's bigger and flows a lot easier
DaveWertz
  • OWF Model: H4
« Reply #20 on: January 24, 2013, 09:22:15 PM »
Most of the copper pipe is 3/4" do you think stepping up to 1" PEX would still push more water threw a 3/4" copper pipe? I think the stove needs a good cleaning inside to. My gram failed to shut it completley down in the summer to fully clean it. Im not joking when I say this but there was 1" of soot that I literally pulled off in sheet like chunks off the sides. The bottom I got what I could without getting inside but in the bottom corners there is still a good bit and some liquid creosot also. Looked like tar. I just stirred that around to see if it would burn off. Im sure none of that helps in heating either.
Stihl Farmboss 290
« Reply #21 on: January 24, 2013, 10:29:25 PM »
Well we don't want to mess with the copper.
You can get underground pex in 3/4", but its hardly any price difference.  If it were all 1" yes it would be better, but having part of it 1" would take "some" resistance out of the system.
