Pages: 1 [2] 3
Author Topic: ok I have pump problems again any ideas  (Read 33838 times)
woodedacres
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250 Coal
Re: ok I have pump problems again any ideas
« Reply #15 on: February 20, 2013, 08:10:06 AM »
got 1 broeder and 1 grundfos. the broeder is real noisy. hope to make it till the end of heating season. i will be contacting scott for a replacement.
« Reply #16 on: February 20, 2013, 08:56:42 AM »
Surprising it's still going if it's been noisy for a while...    They sometimes stay noisy a little while then suddenly rattle and fail
rick n kristi
« Reply #17 on: February 21, 2013, 05:18:53 AM »
Yep; rattle rattle rattle then cold shower. Hope the replacement gets here today! :o :bash:
Natures Comfort 325G
Still 038 magnum
« Reply #18 on: February 21, 2013, 08:53:14 AM »
Hey Rick, just checked the tracking number, it says scheduled delivery on the 22nd.  I was sure hoping it would last until it arrived!!!
rick n kristi
« Reply #19 on: February 21, 2013, 12:29:47 PM »
No problem Scott, My propane was getting stale. I really needed to make sure that side of the system still worked as it's been 3 years 8) I could not have installed the new pump till Saturday anyhow.
Still 038 magnum
« Reply #20 on: February 21, 2013, 12:47:12 PM »
Lol probably don't hurt to fire that old thing up every once in a while lol
rick n kristi
« Reply #21 on: February 22, 2013, 12:20:42 PM »
Pump came in this morning! :thumbup: Been kinda cold here, load of wood from {Tuesday} is still there and burning. Kept boiler temp up, no chance of freezing. I learned somthing else cause of this! Looks like I could shut the pump off and leave for about a week with out worry!
« Last Edit: February 23, 2013, 12:18:45 PM by rick n kristi »
Still 038 magnum
« Reply #22 on: February 22, 2013, 05:21:49 PM »
shut the pump off and leave for a week?...even if your lines are below frost they are not at the OWB...mister, i think you will have problem!
hoardac
  • OWF Brand: Heatmaster G-200
« Reply #23 on: February 23, 2013, 10:59:04 AM »
I would put a inline filter in to reduce the amount of particulate in your water. I have one and it works great stopped the crap from circulating in the water. Just have to schedule clean outs or flushing depending on what type you put in. The are not to expensive.
rick n kristi
« Reply #24 on: February 23, 2013, 12:15:12 PM »
Pump went out Tuesday morning right after I loaded the boiler. Been below freezing every night (high teen to low twenties). No circulation by the pump. Heat exchanger in furnace duct work is getting blasted by propane heated air every time the furnace runs. Boiler still had over half a load this morning with smoke trickling out the stack. Boiler temp at 145 this morning, blower fans been off since Wednesday night. Pump still very hot to the touch. Peeled back the insulation on the lines from the pump down to where they go into the ground, too hot to hold on to. I think I’m gonna be fine for a week at current temps, even a little colder 8)....mister
« Last Edit: February 23, 2013, 12:20:04 PM by rick n kristi »
Still 038 magnum
« Reply #25 on: February 23, 2013, 12:21:22 PM »
Did you get the new pump installed!?
rick n kristi
« Reply #26 on: February 23, 2013, 12:32:23 PM »
Had to work today, leaving now for the farm. Will try to get it in before dark.
Still 038 magnum
« Reply #27 on: February 23, 2013, 12:39:17 PM »
Be sure to crack the bleeder screw before you turn it on...
rick n kristi
« Reply #28 on: February 23, 2013, 12:42:44 PM »
Sure will, I get back on after I switch them out and let ya know how it went. Ready for boiler heat again, momma thinks it's warmer than propane. I think the $ leaving the propane tank cools her off :bag:
Still 038 magnum
« Reply #29 on: February 23, 2013, 12:49:02 PM »
Ain't nothing better than a hot woman lol
Pages: 1 [2] 3
