Pages: [1] 2 3
Author Topic: ok I have pump problems again any ideas  (Read 33832 times)
allis48
  • OWF Brand: natures comfort
  • OWF Model: ncb250
« on: February 10, 2013, 08:06:17 AM »
This is the third pump in say 8 months of burning cause i don't run it year round. I took this one apart and found chunks of black grit stuck in plastic propeller the smaller pieces were bigger bit they broke on removal. It almost looks like black beauty sand blasting shot.
Re: ok I have pump problems again any ideas
« Reply #1 on: February 10, 2013, 09:49:40 AM »
It don't suck off of the bottom of the tank so I don't know what it is, I'm def not crazy about broeders, if it still under warranty call nc and have them allow you credit on the armstrong e9 pump, it's a much better design, flows more water and uses well under half the electricity of the broeder.
« Reply #2 on: February 10, 2013, 03:18:30 PM »
time for an inline filter on the suction side?
allis48
  • OWF Model: ncb250
« Reply #3 on: February 10, 2013, 05:08:50 PM »
I got a b & g I think on It now for the one. Just getting tired changing them
« Reply #4 on: February 10, 2013, 05:38:05 PM »
Well, if it were mine I'd totally drain the entire system, rinse the tank out to the best pf my ability and go from there.  If your using wet rotor pumps that use the water for lubrication and cooling you'll likely continue to have the issue.   A filter may be a good idea as well
« Reply #5 on: February 10, 2013, 06:08:14 PM »
Does that stuff stick to a magnet? I wonder if the pump was magnetizing the rotor enough to pull iron out of the water. It wouldn't surprise me. Those pumps suck so much extra power, maybe they are make the magnetic field way too strong with it. I will have to try testing when I get time if it does stick to a magnet.
« Reply #6 on: February 10, 2013, 06:12:14 PM »
RSI, I never thought of that, it wouldn't surprise me either
« Reply #7 on: February 10, 2013, 06:16:11 PM »
It would also explain why those pumps fail over and over some places and never do at other places. I know a place I had a couple fail at they said they had a lot of iron in their water. It was so bad they had to have a filter system installed just for iron.
« Reply #8 on: February 10, 2013, 06:22:33 PM »
Yep, I just recall a situation here, 3 broeders in a year
He went to a small grundfos and hasn't had issues yet "that I know of"  he was using well water with high iron
Wow, good thinking
allis48
  • OWF Model: ncb250
« Reply #9 on: February 10, 2013, 08:51:35 PM »
I have a lot of iron in the water as well, but the water I used to fill it with was ran thru my house iron filter and water softner other wise the water turns red after about 15 minutes. I also have about 6 bottle of water treatment stuff in it. I am out of town this week will check the crap when I get back to see if it sticks to a magnet.  Do you think they didn't do a good job of cleaning the tank after manfacturing, and has crap left in it from then?
allis48
  • OWF Model: ncb250
« Reply #10 on: February 10, 2013, 08:54:18 PM »
to be fair it has two pumps on it the two orignals went out about the same time about 3 months the one new replacement which is the one that went bad this time from the day the dealer put it on and he was there when I checked with heat gun ran like 30 degrees hot than the other and that is the one that went bad again.
« Reply #11 on: February 10, 2013, 08:57:43 PM »
Sounds almost exactly the same as how the water is and how it was treated where I had the worst problem with those pumps.
allis48
  • OWF Model: ncb250
« Reply #12 on: February 11, 2013, 05:44:35 AM »
How long is the warranty on the pumps on these? My dealer is about  douche I called him about these and said he was going to call them and see was going on but never calls back. Last year he quit answering the phone when I called. I tell people that ask me about unit I liked the unit but hate the dealer. I got hooked up with James vanhorn at NC been big help as well as this site
« Reply #13 on: February 11, 2013, 07:27:06 AM »
1 yr on them broeders
If you have 2 of them broeders pumpin away that's probably over $35 bucks month depending on ur electric rates
rick n kristi
« Reply #14 on: February 19, 2013, 03:19:38 PM »
My original pump almost made 3 heating seasons; I did haul water from the city water plant instead of using my well water which is high in iron. I treat with NC recommended treatment and also pull water samples for a look every year. Samples are clear and I have very little iron residue in the filler neck. New pump is on the way from Scott now cause my current one is rattling like crazy!  :thumbup:
Natures Comfort 325G
Still 038 magnum
Pages: [1] 2 3
