Author Topic: Water heater  (Read 17519 times)
DaveWertz
  • OWF Model: H4
Re: Water heater
« Reply #15 on: May 02, 2013, 07:46:25 PM »
This looks like something to be used if my water heater and OWB were tied together? I have shutoff valves for the water heater so water from the OWB would never reach my water heater when I start burning again. Am I right?
2001 F150 7700 series
09 Harley Superglide custom
Stihl Farmboss 290
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
Re: Water heater
« Reply #16 on: May 02, 2013, 08:32:37 PM »
I think I am gonna burn year round since the wood is so convenient to get to. Hardly use much wood anyway but my next step is insulating the pex lines in the basement so my ac don't have to fight as much with the constant radiant heat. I use a 20 plate heat exhanger and it works sweet.
Re: Water heater
« Reply #17 on: May 03, 2013, 05:48:36 AM »
When properly instaled on an electric gas or oil fired hot water heater the wood boiler will heat all your hot water during the heating season and after the heating season it will automatically switch back over to the original fuel. Suggestion if you are buying a new tank go with a good quality, well insulated tank such as a Marathon as you will not want to do the installation all over again in 3 years when the cheap tank fails, also you should install purge ports and ball valves on all 4 ports of the sidearm in order to clean the minerals ( the same stuff that destroys the elements on electric heater) from the sidearm as it will eventually plug up, If properly installed it can be thoroughly cleaned by the home owner in about 15 minutes without taking anything apart.
d conover
  • OWF Model: H4
Re: Water heater
« Reply #18 on: May 03, 2013, 08:43:07 AM »
My electric bill drops by about $50.00 a month when I am using the Hardy.   Most years I burn the entire year, I only have to put junky wood in it every 3 or 4 days in the summer.  The real dry pithier wood seems to do best.
It makes me happy when the water going into the water heater is hotter than what is going out.
Southeast Missouri
Hardy H4
044 Stihl
038 Stihl
5100s Dolmar
55R husqvarna
CS301 Echo
johnybcold
  • OWF Model: Classic E1400
Re: Water heater
« Reply #19 on: May 03, 2013, 10:34:18 AM »
I use my wood boiler for hot water, I have a hot water storage tank with a zone switch and I love it free hot water feels hotter, I do use my oil furnace to make hot water in the summer, I just turned it on a day ago, I wanted to get a elec tank so I would not need any oil but have not got around to it.
old truck
old craftsman chain saw
Polaris Sportsman 500HO
