Author Topic: solder  (Read 8155 times)
ijon
  • OWF Brand: Portage and main
  • OWF Model: 28-40
solder
« on: May 09, 2013, 03:33:51 PM »
Has anyone ever got bad solder that just won't seal? I just sweat some copper with some new solder I bought and it was like a nightmare. I had just used up some old that I had and no problem with it. Went to the new and all hell broke lose. Am I going nuts?
installed in 2014
Re: solder
« Reply #1 on: May 09, 2013, 05:26:10 PM »
I'm by far no expert, but my experience with the new solder is you need to spend more time making sure the mating ends are absolutely nice and shiny and perfectly clean and use a lot of flux.  When I tried to use the new stuff like I did the old, it would bubble like a cold solder joint and leak.  Once I made the mating pieces nice and clean and shiny with plenty of flux, it sealed really well.    Roger
ijon
  • OWF Model: 28-40
Re: solder
« Reply #2 on: May 10, 2013, 03:44:59 AM »
Thanks, thought I was losing my mind.
installed in 2014
DaveWertz
  • OWF Model: H4
Re: solder
« Reply #3 on: May 12, 2013, 06:37:07 PM »
I just had a valve break loose yesterday afternoon. I to had trouble soldering. I cut out the old valve and cleaned up the copper pipe and new valve. I swear I had that new valve so hot it actually exploded on me!! Im not even kidding. The solder just wouldnt take to the pipe??? Well come to find out I still had a little bit of water in my line which wicked heat away from the point of pipe I was trying to solder. Ughhhhhhhhh. Talk about fun!
2001 F150 7700 series
09 Harley Superglide custom
Stihl Farmboss 290
ijon
  • OWF Model: 28-40
Re: solder
« Reply #4 on: May 14, 2013, 04:05:08 AM »
I soldered one joint on the work bench and it still leaked, so it didn't have any water in it.
installed in 2014
Re: solder
« Reply #5 on: May 14, 2013, 08:48:44 AM »
clan clean and clean...paste both parts of the joint (making sure you get all the way around) concentrate you heat on the outer piece of material, touch solder occasionally on opposite side of where you are applying the heat, as soon as solder melts apply solder to joint and remove heat. that should be all there is to it
cranman
  • OWF Brand: Homesteader
  • OWF Model: 1V
Re: solder
« Reply #6 on: May 14, 2013, 01:49:36 PM »
The non leaded solder is a disaster unless yu use the proper flux and even then it is to be avoided for hydrnics. I always use the 50/50 solder and matching flux and as always ...clean ,clean, clean.
hoardac
  • OWF Brand: Heatmaster G-200
Re: solder
« Reply #7 on: May 15, 2013, 07:37:13 PM »
Cheap flux will cause a problem sometimes I have noticed.
