Author Topic: underground pex  (Read 14219 times)
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
underground pex
« on: May 16, 2013, 02:55:22 PM »
just wondering what everyone uses to seal up around the pipe coming thru there basement walls
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
WoodMOJoe
Re: underground pex
« Reply #1 on: May 16, 2013, 03:11:02 PM »
I thought I would use some of that expanding spray foam, or maybe just pack the hole with some kind of hydraulic grout.
automan77
Re: underground pex
« Reply #2 on: May 16, 2013, 03:14:08 PM »
I looked on the home Depot site and they have quickete hydyaulic water stop cement. Might just use that. wonder if anyone used it?
Scott K
Stihl ms 311
Husky 455
Re: underground pex
« Reply #3 on: May 16, 2013, 05:21:55 PM »
I use spray foam...  No leaks
fireboss
Re: underground pex
« Reply #4 on: May 26, 2013, 06:55:37 AM »
I put a bag of cement on outside  and spray foam on in side
Kingfisher5555
  • OWF Brand: None
Re: underground pex
« Reply #5 on: May 26, 2013, 07:25:59 AM »
I spray foamed and used hydraulic cement
Re: underground pex
« Reply #6 on: July 31, 2013, 09:23:18 AM »
I use hydraulic cement, looks good,no leaks, inexpensive, use a wet rag to clean the patch area up and it will blend right into the wall when dry
Acetylene420
  • OWF Brand: Home Built
Re: underground pex
« Reply #7 on: September 08, 2013, 05:52:08 AM »
I've done excavating and septic system installs for years.
Whenever we switch out old cast iron waste pipe for pvc through foundation I always use the Quickcrete Hydralic cement.
The stuff seals beautifully and is more of a putty consistency rather than mushy cement. You can really press it in all around the pipe.
Just keep in mind it hardens very quickly. Like 10 minutes quickly. Make sure you are all prepped and ready to slop cement before you mix it. Only do a small amount in a 5 gallon bucket at a time. The stuff is like Bondo with too much hardener. It locks up quick.
Re: underground pex
« Reply #8 on: September 08, 2013, 08:53:07 AM »
Is this hydraulic cement something available at a local big box store?  I've not seen it and always used foam, no issues but I like the idea of it
automan77
Re: underground pex
« Reply #9 on: September 08, 2013, 11:16:55 AM »
you can find it at Home depot
Scott K
Stihl ms 311
Husky 455
Re: underground pex
« Reply #10 on: September 09, 2013, 05:15:56 AM »
It works well and can be purchased at Hd or any masonry supply house, I personnally prefer to stay out of the box stores and shop at the real supply houses
Re: underground pex
« Reply #11 on: September 09, 2013, 07:08:59 AM »
A supply house, I've never even heard of such things down here lol
There is a few mom and pop hardware stores, usually one in every little town but they rarely have any fittings over 3/4" and def no pex stuff
There is a plumbing store I use when I'm in the area, but it's 2 hours away..
Re: underground pex
« Reply #12 on: September 09, 2013, 07:26:42 AM »
I know and up here there is a supply house in almost every medium sized town.
Re: underground pex
« Reply #13 on: September 09, 2013, 08:06:25 AM »
There is one plumbing store about 40 mins from here
there higher than lowes tho at retail
they charge 24.99 for a 20ft stick of pex
Re: underground pex
« Reply #14 on: September 10, 2013, 04:36:58 AM »
I have never bought Pex in the stick form. I think my Vega- Fosta Pex is retail around $1.80 per foot and comes in a roll of 100 or 500 feet.
