Author Topic: Pump Selection  (Read 13266 times)
uncle
Pump Selection
« on: September 25, 2013, 08:26:56 PM »
Reading the previous post, I hope I got the right pump???
I have a run one way of 220' and a 30 plate heat exchanger.
What pump would you suggest?
I have a Grundos UPS15-58FC.
Brian
Re: Pump Selection
« Reply #1 on: September 25, 2013, 08:42:41 PM »
To small
Re: Pump Selection
« Reply #2 on: September 25, 2013, 09:28:55 PM »
What size pipe?
Re: Pump Selection
« Reply #3 on: September 26, 2013, 07:38:28 AM »
I was assuming he had 1" pex....  Maybe he'll be back
uncle
Re: Pump Selection
« Reply #4 on: September 26, 2013, 01:45:43 PM »
1" pex all the way.
Brian
uncle
Re: Pump Selection
« Reply #5 on: September 26, 2013, 08:04:02 PM »
I have a second pump for my second loop, a Bell and Crossett NPF22.
That loop it 55' of 1" with only a water to air exchanger.
What do you think of this one?
Brian
Re: Pump Selection
« Reply #6 on: September 26, 2013, 08:16:20 PM »
That one should be fine.
For the 220' run you could add another 15-58 in series or get something like a 26-99 or b&g pl36.
uncle
Re: Pump Selection
« Reply #7 on: September 26, 2013, 08:59:18 PM »
I might keep the 15-58 for a spare/emergency pump and get the pump you quoted.
Thanks,
Brian
uncle
Re: Pump Selection
« Reply #8 on: November 03, 2013, 02:54:22 PM »
I didn't mean to bring this back up but I need a little help.
My run to the house is 220ft one way of 1" pex. I have a 20x20 water to air hooked up. From the pump through the whole loop, there are 2 shark bite 90's total. I want to plumb in a 30 plate water to water and this will take a few more fittings.
What would be an estimate of my head and would the 26-99 still be a good pump?
I am using the 15-58 just to get heat moving but I want to do what I can to make it right.
Thanks,
Brian
Re: Pump Selection
« Reply #9 on: November 03, 2013, 02:57:40 PM »
Grundfos 26-96 would be better..  I often say 26-99 but mean 26-96.
Re: Pump Selection
« Reply #10 on: November 03, 2013, 07:39:08 PM »
What is the reason to use a 26-96 instead of a 26-99? That may be a little small for 220' each way? You can always use medium on the 26-99 it is a little big and it doesn't cost that much more..
Re: Pump Selection
« Reply #11 on: November 03, 2013, 08:07:19 PM »
Yea..  Your right, I was looking at the curves wrong
Re: Pump Selection
« Reply #12 on: November 04, 2013, 04:05:58 AM »
What is the heat load like, I normally try to size circs with that in mind, is the 1 inch pex inside diameter or is it nominally sized, a good rule of thumb is 1 gallon of water per minute = 10,000 btu extracted at the heat exchanger, 10 gallons per minute = 100,000 btu output, on a long run like this, sometimes it helps to double up the circs, one on each end of the line.
uncle
Re: Pump Selection
« Reply #13 on: November 04, 2013, 07:43:46 AM »
It's just standard 1' PEX, the sharkbites work perfect.
Can we visit pump speed that you mentioned? How would I know if I needed to slow the pump or speed up the pump?
I've got the small pump on it now just to get heat moving but I have not connected the 30 plate yet.
Brian
Re: Pump Selection
« Reply #14 on: November 05, 2013, 11:56:58 AM »
Speed up the pump or flow rate if the differential is over 20 degrees and slow it down if under a load you are less than 10 on the differential
