Pages: 1 ... 4 5 [6]
Author Topic: thermostat wiring  (Read 37900 times)
bearfeet
  • OWF Brand: earth
  • OWF Model: woodsman 405 { in process }
Re: thermostat wiring
« Reply #75 on: November 12, 2013, 05:26:30 PM »
maybe I missed something.  can someone   please    show a thermostat  wiring/color diagram of a  o.w.b  to a gas furnace with  a/c.??
do you need a zone valve & a bypass right before the heat exchanger to keep the water from circulating thru the coil or does the thermostat bring the pump on & off.. ?/
thanks
« Reply #76 on: November 12, 2013, 06:45:30 PM »
Most people have the water circulating through the heat exchanger 24/7 and just turn the fan on and off with the thermostat.
The fan connection is usually the green wire and is the G connection. The W wire is the heat connection. To run the fan for the OWB, you just connect the G wire to the W on the thermostat you are using for the OWB. If you are using two thermostats the RH needs to be connected to both and the C should be if it is on the original. Just using jumper wire between the two thermostats works fine. The G (from furnace side) should be not be connected to both thermostats, only the one for the OWB.
bearfeet
  • OWF Brand: earth
« Reply #77 on: November 13, 2013, 03:18:06 AM »
can you please post a wiring diagram & show the connections.
thanks....
