Author Topic: welding process  (Read 9509 times)
kjw58
  • OWF Brand: Natures Comfort
  • OWF Model: 275G- Coal Burner
welding process
« on: February 21, 2010, 09:23:09 PM »
Just wondering what you guys feel is better for mig welding 1/4 mild steel on owb.  Flux core or gas shielded  ??  Thanks
S.E. Mich.
New Holland TC40DA
IH 464 w/2250 Loader
6 x 10 Dump Trailer
2 Stihl 261's
Poulan 3400 & 3700
Poulan 2150
Homelite Super XL
MarkP
  • OWF Brand: Homebuilt
  • OWF Model: Hillbilly #3
Re: welding process
« Reply #1 on: February 22, 2010, 04:14:57 AM »
If you are welding inside, gas shield is the way to go.  Clean weld, with less chance for porosity.  Flux wire is great if you are welding outside where the wind will blow the  gas away from the weld area.
Homemade OWB  (Smokey)
Stihl 290, 2 Stihl 170s
Tractor supply 22 ton splitter
One good woman that can cut and split wood
Le Roy, WV
boyland
Re: welding process
« Reply #2 on: July 28, 2010, 09:07:44 PM »
depending on the voltage flux will weld heavier gauge steel.  Otherwise gas is good.
IMO
mober
Re: welding process
« Reply #3 on: July 29, 2010, 03:04:22 PM »
arc 6010 fleet weld 8)
Re: welding process
« Reply #4 on: July 30, 2010, 06:06:16 PM »
arc 7018  got too heavy for my little loader and had to position weld quite a bit of it
