Author Topic: Rainwater and clorox  (Read 7847 times)
Sawdust
« on: October 14, 2013, 10:02:31 AM »
I have a catch container to collect rainwater  water to fill my outdoor wood furnace. Occasionally I add about a table spoon of bleach to the water to retard algae growth. Would appreciate others opinions as to whether or not this will damage the boiler. Thanks, Sawdust
Re: Rainwater and clorox
« Reply #1 on: October 14, 2013, 10:15:54 AM »
Why are you feeling it necessary to use rainwater?
Sawdust
« Reply #2 on: October 14, 2013, 10:28:41 AM »
I use rainwater because my only other source of water is my well. The well water is very high in lime content, so much that it actually collected in my W/W  exchanger and in my W/A exchanger that I had to pull them and soak them in white vinegar for a week or so to get them cleaned out last season. I was losing at least 60 percent or more of flow through the system.
« Reply #3 on: October 14, 2013, 01:09:02 PM »
Yep, that hard water can be rough...
I'm not sure on what small amounts of Clorox would do though or if it Evaps and don't hurt anything
RSI may know
« Reply #4 on: October 14, 2013, 01:36:31 PM »
I don't know if such a small amount will hurt anything but bleach is very corrosive. Here is something that came up with a google search.
Quote
Bleach is corrosive. "Bleach can drill a hole through stainless steel," says Curriden, "that's why it's important to wipe down metal surfaces with water or ethanol after treating them with bleach." For delicate metal instruments, consider avoiding bleach altogether and using a different kind of disinfectant, such as ethanol.[/quote)
http://www.scripps.edu/newsandviews/e_20060213/bleach.html
If your water is that bad, I would get a water softener. That will also solve the possible plugging on the other side of the plate.
« Reply #5 on: October 14, 2013, 02:53:55 PM »
That's what I was thinking but wasn't sure
Pelican maybe? Lol
BoilerHouse
  • OWF Brand: Home Built
« Reply #6 on: November 06, 2013, 05:25:18 PM »
As Yotehunter67 said; A table spoon of bleach to a barrel of water will do no harm.  Using a quality boiler water treatment will get the pH and alkalinity within the proper range.
Muskoka, Ont
Flyfishjt
  • OWF Brand: Earth
  • OWF Model: Woodsman 405
« Reply #7 on: November 06, 2013, 08:07:17 PM »
Idk about the bleach but I do know that you are doing the best thing possible by using rainwater. I talked with the owner of hardy even tough I don't own a hardy and he said the #1 killer to all owb is salt and that rainwater has the least amount of salt and corrosive materials in it. I wish I could've been patient enough to collect enough rainwater atleast for my  1st fill.
