Author Topic: Shaver Furnace Construction Questions  (Read 11191 times)
Jim-NH
  • OWF Brand: Shaver
  • OWF Model: Pro Series Model 340
« on: November 02, 2013, 10:53:48 AM »
In New Hampshire - Shaver Pro Series Model 340 - 300+ gallons, 3 zones
I would like to speak with anyone who has replaced the floor pan on there shaver furnace.
Mine is leaking badly.  Is the floorpan welded to anything but the legs and sidewalls? Does the end plates of the burn chamber rest on the floor pan or weld to it?  If I cut the sidewall just above the wall/floor seam will a flat sheet of steel be able to reweld to new cut along the walls without any bending?
I saw a posting from a guy who just about rebuilt his shaver furnace.  All improvement suggestions that provide benefits are welcome. please respond to my posting.  I'm tearing it apart now.  The factory hasn't responded to repeated phone calls or emails.  I did all water tests and treatments.
I added electronic temp control and big fan with damper.
I'm looking to improve;
rusting issues & repairs
Has anyone experience with anode rods like in electric domestic H2O heaters-would it help?
insulation - spray foam , sheet foam or fiberglass
adding a drain plug
Improving return water plumbing
Thanks Jim
reply here or call 603-974-3056
Roger2561
Re: Shaver Furnace Construction Questions
« Reply #1 on: November 03, 2013, 03:00:24 AM »
Jim, - Welcome to the forum.  I do not know anything about the Shaver boilers, I have a Central Boiler.  Be patient, someone will eventually pop in and offer you assistance.
I'm in NH too.  We a few members on here from NH.  Where in NH do you live?  I'm in the Upper Vally area, small town about 15 miles So. east of Hanover/Dartmouth College.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
gandgracing
« Reply #2 on: November 03, 2013, 06:47:38 AM »
When we tore mine apart the burn chamber was not welded to the floor.  While you have it apart run your cold water return lines to the front of the stove.
rugerman
  • OWF Brand: shaver
  • OWF Model: 250
« Reply #3 on: November 04, 2013, 08:54:28 AM »
welcome to the world of shaver going thru same thing right now only they have my stove at the factory been there since 9-30-13    cant get a response called and emailed  anyone that buys one of these stoves from these people better take a good look at what you are dealing with  if I run a business like that I would be broke //// something should be done with this company
« Reply #4 on: November 04, 2013, 12:18:44 PM »
You are doing it, they have to be feeling the heat, Truly sorry to hear of your misfortune and thier inability to stand behind thier product, don't give up.
rugerman
  • OWF Brand: shaver
  • OWF Model: 250
« Reply #5 on: November 04, 2013, 12:34:34 PM »
not planning on giving up   may freeze to death  tho    lol
« Reply #6 on: November 04, 2013, 03:52:16 PM »
they ignore the heat, seriously, wed probably fall over if we knew how many people were in this same situation.  I meant they ignore the heat by ignoeing calls and emails
