Author Topic: Loading an nc175  (Read 12567 times)
steve.b
  • OWF Brand: natures comfort
  • OWF Model: ncb 175
Loading an nc175
« on: November 08, 2013, 08:11:10 AM »
Is there some kind of secret to loading the stove or do they all bridge the wood? I am new to this and work nights. I usually work 12 to 14 hours a night and am afraid that it will bridge the load and go out. Just wondering.
Re: Loading an nc175
« Reply #1 on: November 08, 2013, 08:49:04 AM »
Shouldn't have no bridging issues in a conventional style boiler
artbaldoni
  • OWF Brand: Nature's Comfort
« Reply #2 on: November 08, 2013, 10:44:48 AM »
I have been burning mine since Dec 2010 non stop. May have bridged 2-3 times that the fire actually went out. In cold weather I load at 12 hour intervals. Sometimes a little longer.
Check your temp setting and maybe look at the damper door gap. If the ap is too large maybe it could lead to a bridging issue. I think mine is around 1/4". Not sure its been a long time since i set it.It was wider than that from the factory.
I love mine. Good luck!
Nature's Comfort  NCB-175
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
Bobcat 7753 w/EEL Tracks
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
SKAMPO
  • OWF Brand: Nature Comfort
  • OWF Model: 175
« Reply #3 on: November 08, 2013, 03:46:53 PM »
If you burn a lot of rounds and not much split pieces it can happen more. Try checking the blower damper and try different ways of loading rounds so they don't bridge as bad. A little more experience and you'll figure out what works best.
Guru
    • Mike's Advanced Heating
« Reply #4 on: November 11, 2013, 07:14:07 AM »
I just hooked up a NCB175 to my house to try out for the year.  I am a NC dealer so I like to try different models to see how they compare.  I am heating a 2200 square foot house, DHW and a 600 square foot garage.  So far it is working great.  I did notice laoding a 10" round piece in the center and then split stuff around it seems to give me the longest burn times.  Also I have never had a bridging problem with the NCB updraft boilers.
I will be experimenting with the boiler all season so if I come up with any other modifications or practices I will let you know.
Mike
Caro MI
steve.b
« Reply #5 on: November 11, 2013, 11:59:34 AM »
thanks for the replies
JDfarmer
  • OWF Brand: NCB 250 coal
  • OWF Model: NCB 250 Coal
« Reply #6 on: December 13, 2013, 09:00:33 PM »
I have a new 250 Coal. The blower is in the back, so actually if I burn wood, it burns great in the back, but also very well in the front. I have had zero issues with wood not burning all the way. If I let the boiler just go for 12-14 hrs, and not reload, all the wood will be just powdered ash, no matter how I load it.
I mainly use coal (anthracite), and I get 18-24-26 hrs with that between loads.
I do have shaker grades, it's a 250Coal.
We've been very happy with the boiler.
Our house is 4450 sqft well insulated, heating the 80g a tank of water as well. We keep the house at 72F
I do have a hard time getting more than 12hrs out of the boiler between reloads just on wood. With coal, no problem 24 hrs.
« Reply #7 on: December 14, 2013, 08:55:16 AM »
Yep but the airflow in your coal model is nothing like the airflow in a reg 250, thats why it burns more evenly
JDfarmer
« Reply #8 on: December 14, 2013, 09:03:44 AM »
So, is the airflow better on the 250coal model?
Scott; can you explain how to adjust the damper door? I don't understand how open should it be. Should I open all the way, and close it until the fire is still burning well, or just open all the way?
Thank you
[/quote]
[/quote]
steve.b
« Reply #9 on: December 14, 2013, 09:04:30 AM »
I can load mine up and it will burn the middle but will not burn the sides. The slots in the bottom aren't clogged, but even with the cold temps I can still get 24 burns out of one load.
JDfarmer
« Reply #10 on: December 14, 2013, 09:14:33 AM »
That's great. What kind of coal are you burning?
And what are your settings?
steve.b
« Reply #11 on: December 15, 2013, 11:40:47 AM »
I don't have a coal I just burn wood.
