Author Topic: Thermostat/blower/need heat?!  (Read 13841 times)
Re: Thermostat/blower/need heat?!
« Reply #15 on: November 16, 2013, 07:47:53 PM »
That will work but will cost more than just a standard relay and it won't be able to run a zone valve if one was needed unless you go with the double pole version.
« Reply #16 on: November 17, 2013, 04:41:55 AM »
Check the amp draw on the blower, if it is below 5 amps then a Taco 501 circ relay will do the job, if it is over 5 amps you will need a non fused relay such as the ARGO, they can be bought at any plubing supply house.
4CSTRAILS
  • OWF Brand: Dahl
  • OWF Model: 230
« Reply #17 on: November 18, 2013, 06:35:04 PM »
Having a little trouble finding a relay in my area. Small town rural area with no big stores. My blower amp spec is 6.6 amps. Typed argo in a search and came up with this ARGO AR-821T RELAY TRANSFORMER
SWITCH CONTROL
115v   60cy   DPST   24va   24v SECONDARY
Is this what I am looking for?
