Author Topic: Odd noise  (Read 9869 times)
bcanode
  • OWF Model: MF4000E
Odd noise
« on: November 19, 2013, 07:02:31 AM »
Best way to describe this is it sounds like something hard left in a dryer when it is tumbling.
It's happened a few times and it seems to be when the fire is really roaring during a heat up cycle.
Anything I should be worried about?
Re: Odd noise
« Reply #1 on: November 19, 2013, 08:28:51 AM »
What do you have for a boiler? Sounds to me like its either the firebox, water jacket or outer sheathing around the boiler expanding when a heavy heat load is on it.
bcanode
Re: Odd noise
« Reply #2 on: November 19, 2013, 08:56:16 AM »
Heatmaster MF4000E
« Last Edit: November 19, 2013, 08:57:47 AM by bcanode »
Re: Odd noise
« Reply #3 on: November 19, 2013, 09:01:00 AM »
Scott should be able to chime in here with some insight about that. All of the heatmasters are stainless correct? I know that my Hardy which is stainless can make some popping noises once in a while due to temperature changes.
baldwin racing
Re: Odd noise
« Reply #4 on: November 19, 2013, 09:52:02 AM »
is it just fell down in and is bouncing around in the squirrel cage.....?  when calls for heat it kicks on and it bounces around in there?
kelly
husqvarna 357 xp
farmall H
bcanode
Re: Odd noise
« Reply #5 on: November 19, 2013, 10:48:20 AM »
It's hard to describe. Sounds like the flames are periodically beating on the sides.  Hard to describe without sounding a like a who's on first skit.....
Re: Odd noise
« Reply #6 on: November 19, 2013, 11:57:27 AM »
Its hard to say with out some more Info, in the past whIle running 5000e ive heard a thump or something under heavy load but not sure if thats what your hearing or not
idahohay
Re: Odd noise
« Reply #7 on: November 19, 2013, 01:05:03 PM »
One thing that came to mind was is the boiler full?
bcanode
Re: Odd noise
« Reply #8 on: November 19, 2013, 01:19:26 PM »
Could be described as a continuous thumping. Boiler is full.
Re: Odd noise
« Reply #9 on: November 19, 2013, 01:46:44 PM »
What happens when you open the loading door? Go away, continue, get worse? Sounds like idaho hay may be on the right track. Could be water boiling somewhere in the unit. Does the thumping slowly reside when the forced draft fan stops blowing?
ITO
  • OWF Brand: HS1
  • OWF Model: 555
Re: Odd noise
« Reply #10 on: November 19, 2013, 01:50:35 PM »
What you are describing sounds like boiling water to me.
Flyfishjt
  • OWF Brand: Earth
  • OWF Model: Woodsman 405
Re: Odd noise
« Reply #11 on: November 19, 2013, 02:57:48 PM »
Sounds like backdraft! Open door and it'll go away.
Re: Odd noise
« Reply #12 on: November 19, 2013, 04:29:24 PM »
Not sure about the backdraft theory. A backdraft condition would be caused by a fire that has consumed all the available oxygen available to it but remains EXTREMELY hot and only needs an introduction of air to cause a massive explosion from the introduction of the much needed air.
Re: Odd noise
« Reply #13 on: November 19, 2013, 06:40:40 PM »
The 4000e introduces air at the top of firebox as well as under the coal bed, the thumping "could be" the gases off the wood being burnt off by the top draft every moment or two
