Author Topic: what to use for gasket around chimney pipe  (Read 5392 times)
gully505
  • Newbie
  • OWF Brand: heatmaster
  • OWF Model: mf5000
« on: November 23, 2013, 11:03:00 AM »
Has anyone had to replace the gasket around the chimney coming out of the top of the wood stove?  I am using a heatmaster mf5000 and the gasket was damaged around the chimney pipe.  Would high temp silicone (500 degree+) work?  Using selkirk ultra high temp double walled insulated chimney.  Thanks!!
Re: what to use for gasket around chimney pipe
« Reply #1 on: November 24, 2013, 07:15:17 AM »
Yes that will be fine
duke
  • OWF Model: MF5000
« Reply #2 on: November 25, 2013, 07:51:58 PM »
I need to do the same mine is coming off too.
06 Duramax
08 Polaris Ranger XP
MS 310
28 ton Swisher
gully505
  • Newbie
  • OWF Model: mf5000
« Reply #3 on: November 26, 2013, 06:52:23 PM »
Thanks for the info, the original gasket looked like a type of silicone but didn't know if it was one that was available to the average joe or something only available for industrial use.
