Pages: 1 2 [3] 4
Author Topic: Heatmaster MF 10000e tank burned out after 2 years of use  (Read 29807 times)
Atwelltony
  • OWF Model: Mf10000
Re: Heatmaster MF 10000e tank burned out after 2 years of use
« Reply #30 on: December 12, 2013, 08:43:16 PM »
The best we can tell we have went thru 5 pumps, a relay, and a couple of valves that are mounted in the plumbing from the stove to my house one thing we have noticed the second pump on the stove is a shorter run and we haven't had to change that pump it's only been the pumps on the house side that has went out over and over since they are pumping the same water would that lessen the possibility of something corrosive? So to narrow it down the pump that runs our shop heaters so far has had no trouble, the circuit that goes to my house and pool have 2 pumps stacked one on top of the other and they are wired to never shut off they keep the water circulating , these are the pumps I've had to change my dealer came last week and changed them again
Any ideals
« Reply #31 on: December 12, 2013, 09:02:32 PM »
 What kind of pool and any trouble with it?
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #32 on: December 13, 2013, 05:51:23 AM »
What does your exchanger system look like for the pool?
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
« Reply #33 on: December 13, 2013, 10:33:49 AM »
I think we now see a red flag on what this could be....
What type of pool?
Atwelltony
« Reply #34 on: December 13, 2013, 05:08:40 PM »
It's a titanium heat exchanger for my pool
It's a salt water pool
Atwelltony
« Reply #35 on: December 13, 2013, 05:10:59 PM »
The pool heat exchanger looks good no issues with the titanium
Atwelltony
« Reply #36 on: December 13, 2013, 05:13:26 PM »
No trouble with pool
Atwelltony
« Reply #37 on: December 13, 2013, 05:26:55 PM »
Note on pool heat exchangers from what I've been told u need a titanium with salt water pools and not the stainless we have had issues with the stainless heat exchangers leaking around where the fitting flanges are welded to the exchanger , we would get a pin hole
« Reply #38 on: December 13, 2013, 09:24:47 PM »
If one of the tiny tubed inside the shell had a pin hole that would explain it all
Atwelltony
« Reply #39 on: December 14, 2013, 12:05:03 PM »
So what are u thinking could be the cause?
« Reply #40 on: December 14, 2013, 12:21:30 PM »
 I've heard if you get salt into the water jacket it will eat the stainless out.
Atwelltony
« Reply #41 on: December 14, 2013, 01:12:51 PM »
That def would be a possibility
I'm going to try and get some more water tests from a advanced lab out west I think they can shed some light on things
Thanks for all the replys and input on this subject  and I would also like to note that heatmaster has stood behind this 100% they have sent us a new tank and our dealer is waiting for warm weather to change it out so regardless what the problem we are a totale satisfied heatmaster customer and we highly recommend there products and service
Tony Atwell
Tg manf.and sales
Www.tgsales.com
Boydz
  • OWF Model: 10,000E
« Reply #42 on: December 27, 2013, 08:21:05 AM »
Tony,
SO happy to hear that Heatmaster is backing you up and has taken care of you. While I've had zero issues with my setup, its nice to know that if I do, they will be there for us.
If it was me, Id be doing a 24hr leak down pressure test on that Titanium Heat exchange ASAP before opening that loop back up again once you are up and running. It would be interesting to go back in time and see if your tank levels were fluctuating at all. Salt is such a PITA :) As stated, this may be the issue, even in small doses.
HeatMaster 10,000E
Atwelltony
« Reply #43 on: December 28, 2013, 12:49:49 PM »
That is good advise we actually did a test this past month to make sure no pool water was getting into the stove we had a plumber who was installing a sterling water softener system for us unhook the lines at the pool loop and he ran a vacuum and pressure test ,,,, everything was good
We did have another lab run some tests for us that could check for chlorine and they said there was no trace of it or salt so we are still investigating
Very glad to hear you haven't had any issues with your unit I'm hoping we got a lemon and the next one will be trouble free
Boydz
« Reply #44 on: January 29, 2014, 09:21:46 AM »
Any updates on this ?
HeatMaster 10,000E
Pages: 1 2 [3] 4
