Author Topic: Major Issue Help!  (Read 13985 times)
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
Re: Major Issue Help!
« Reply #15 on: December 15, 2013, 10:50:18 AM »
Good deal glad to hear your back online.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
baldwin racing
« Reply #16 on: December 15, 2013, 10:52:12 AM »
Hey guys - found a small leak last night around 10pm, right off the back of the stove water was running down the return line from a bad compression fitting.  Got it fixed up with a sharkbite and monitored all night - seems to be holding water no problem - funny how a small drip can turn into a monster.
glad it was an easy fix....it is amazing how much water leaks out of a little drip....
kelly
husqvarna 357 xp
farmall H
« Reply #17 on: December 15, 2013, 10:56:09 AM »
Glad to hear it nothing serious.  Those small leaks are the most difficult to find.  I had one last year inside the basement behind oil furnace.  The problem was it drained into the floor drain so I didn't notice it until one morning I decided to check the water level for giggles and it was down quite a bit but not enough to cause any problems.  It was a loose fitting.  No more leak problems.  Roger
cantoo
  • OWF Brand: Western Pacific
« Reply #18 on: December 15, 2013, 03:09:20 PM »
Moral of the story, add a few sharkbite fittings and a few feet of each of the sizes of hose you use to your stash of spare parts. I keep enough to hopefully keep me going if I spring a leak.
