Author Topic: central boiler eclassic 3200  (Read 4462 times)
pook
  • OWF Model: eclassic 3200
« on: January 01, 2014, 11:51:00 AM »
I've been having two problems with my OWB.  on the same day the lights on the outside of the stove stopped working and the bypass alarm stopped sounding?? Has anyone else had this problem??
Jack72
  • OWF Model: E-1450 (11)
Re: central boiler eclassic 3200
« Reply #1 on: January 01, 2014, 04:06:17 PM »
Pook
I know I answered you on the Foestry Forum but I copied the same thing so others would know
Yes that happen to mine the first year.   My dealer replaced the buzzer and that took care of the lights
the LED lights are/connected off the buzzer some reason.    No problem since
I have the 1450 same set up as the 3200
The buzzer is inside the control Firestar panel
Hope this helps.
Jack.
Chevy 2500 HD 13 Duramax
Stihl 046 036 009
Northern Tool 25 ton Splitter
boilerman
« Reply #2 on: January 02, 2014, 09:17:03 PM »
Pook,
The wiring schematic shows there is a low voltage transformer that powers the LED lights and buzzer.
Perhaps that transformer has failed since neither of those items are working.
I would check with your dealer.
Jack72
« Reply #3 on: January 03, 2014, 04:49:13 AM »
Pook,
Pook
Boilerman is correct the transformer does control/power to the beeper and the lights       The transformer is inside the gray cabinet back of stove above the fan
But in my situation the beeper/alarm was bad causing it to blow
my transformer and we put a new one in which may be your problem but we installed two and fried one more before realizing the buzzer was bad or shorting out causing the transformer to fry
Hello boilerman nice hearing from you
Jack
« Last Edit: January 04, 2014, 06:44:18 AM by Jack72 »
Stihl 046 036 009
