Pages: 1 [2] 3
Author Topic: wood size vs recovery time = less heat?  (Read 21959 times)
cantoo
  • OWF Brand: Western Pacific
Re: wood size vs recovery time = less heat?
« Reply #15 on: January 05, 2014, 08:43:08 AM »
I have a Pacific Western own that I just put in last fall. I have a variety of wood to burn in it.
 Oak slabs from a sawmill, small little pieces burn like heck.
 16 to 20" Poplar splits last summer, dry as a fart and lots of quick heat but short lasting.
 16 to 20" Hardwood splits from tree tops ash, maple, walnut etc. Burns real hot, stove holds lots but not real long burn times.
 6 to 10" dia x 48" long cherry logs, These are great, throw them in, lots of heat and long burns.
 Old hydro poles 10"x 48" long (not treated) These also were great but I only have a few left. Stack them in last fall and I was getting 2 or 3 day burns out of them.
Next year I will be cutting longer lengths of stuff and very little splitting. I still have 10 cords of split hardwood to get quick heat if needed. If only I had a source of cheap coal.
DaveWertz
  • OWF Model: H4
« Reply #16 on: January 05, 2014, 06:45:54 PM »
Is the little notch the indicator for the low recovery temp. This is a honeywell aqua stat?
2001 F150 7700 series
09 Harley Superglide custom
Stihl Farmboss 290
« Reply #17 on: January 06, 2014, 06:14:34 AM »
Dave, if thats the aquastat that I think it is, the metal dial is your cut out temp and the smaller white dial is the differential or temp cut in below cut out.
DaveWertz
  • OWF Model: H4
« Reply #18 on: January 06, 2014, 02:07:04 PM »
Slim the white is the diff. I couldnt get a pic with the metal dial because the little white dial "diff" sits behind it.
Stihl Farmboss 290
« Reply #19 on: January 06, 2014, 05:12:47 PM »
OK Dave the metal dial is setpoint, the boiler should shut off at setpoint, the diff or white dial is cut in temp, example setpoint of 185 with 10 degree diff, boiler runs up to 185 and shuts off, it will come back on at 175
DaveWertz
  • OWF Model: H4
« Reply #20 on: January 06, 2014, 06:31:33 PM »
Gotcha. Thats what I set it at tonight as we are having high winds and dipping down to negative numbers.
Stihl Farmboss 290
walkerdogman85
  • OWF Model: H-4
« Reply #21 on: January 07, 2014, 08:51:57 AM »
this year is the first year that i have burnt big rounds, just beacuse i cleaned up my pile.. i have nice split and stacked wood that is seasoned and if i loaded the box up with rounds i had a hard time keeping it going so i would then put dmaller splits on the bottom and then a few big rounds. i have a log splitter but my brother has it so i cut all of my rounds into 6' rounds and then split them they seemed to burn better than big rounds.. but now i am into season splits with great results good burn times and great recovery times, now if i had new windows and doors i would be in great shape lol
Michael West
Central Ohio
fryedaddy
  • OWF Model: 750 Gallon
« Reply #22 on: January 07, 2014, 08:57:54 AM »
I normally mix large rounds with split wood on cold nights.
DaveWertz
  • OWF Model: H4
« Reply #23 on: January 07, 2014, 12:42:10 PM »
I hear ya walker! I got all new windows threwout the entire house even in the basement and attic. It did help. Tomorrow im having a contractor come and give me an estimate on cellulose blown insulation.  Im excited to help keep thehewat in and cold out!
Stihl Farmboss 290
« Reply #24 on: January 07, 2014, 01:46:50 PM »
If I can't get my hand across the block, when its green, I split it; kind of a hold over from the old day with indoor wood stove.  Cause if I couldn't pick it up with one hand green it would not fit in the stove and the wife could not pick up the blocks.
By the way, "my hand size guide" means that anything over about 9" gets be split
d conover
  • OWF Model: H4
« Reply #25 on: January 09, 2014, 01:15:58 PM »
Starting this year I starting splitting down to "hand size" at 56 years old my back was feeling the bigger stuff, it takes a few seconds to split a block and a backache for me is all night...
Southeast Missouri
Hardy H4
044 Stihl
038 Stihl
5100s Dolmar
55R husqvarna
CS301 Echo
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
« Reply #26 on: January 15, 2014, 09:38:25 AM »
 :thumbup:
Michigan Thumber
dukethebeagle
  • OWF Model: 0001 hot tamali
« Reply #27 on: January 15, 2014, 10:22:28 AM »
for sure big round blocks last long but they won't burn as intense especially if the stove is natural draft.
i always wack em in half.i know they don't last as long but it don't take all day to get going
and it  ewasy to keep up to temp.instead of filling the stive up full just load smaller loads a little more often
  just my opinion :thumbup:
austin qc
bluegrass rules
proud appalachian
d conover
  • OWF Model: H4
« Reply #28 on: January 15, 2014, 01:14:19 PM »
I also noticed since I started splitting almost everything my wood hasn't bridged and went out once.
I don't know if that is an issue with anything but Hardys but I used to have my fire die down and all but go out from bridging..
Southeast Missouri
Hardy H4
044 Stihl
038 Stihl
5100s Dolmar
55R husqvarna
CS301 Echo
franky1
« Reply #29 on: January 15, 2014, 01:55:26 PM »
I have seen where big logs would not fall down,,and therefore my stove went cold,,,they got caught half way down and did not hit the ashes....
learned my lesson,,,only 1 big one with few smaller ones..\
Pages: 1 [2] 3
