Author Topic: Ridgewood 7500 Delivered  (Read 14885 times)
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
Re: Ridgewood 7500 Delivered
« Reply #15 on: January 20, 2014, 07:44:33 PM »
I read their page and didn't see anything about a new stove. All I found was the epa stuff.
 The new EPA government regulations will be going into effect in 2015. Be sure to purchase a quality built stove before that time. If you do your research you will learn that many of the new "high-efficency" stoves are poorly built –all glitz and lots of electronics. They have cut corners to get them quickly passed by the EPA. Remember,EPA does not test for quality,they only test the stack for impurities.
If you want a quality,heavy built stove - the Ridgwood stove –that's exactly what we have.
Buy now,before you're only choice is a EPA certified,but quality minimized competitor stove.
« Last Edit: January 20, 2014, 07:46:10 PM by victor6deep »
wissel12
  • OWF Model: 7500
« Reply #16 on: January 20, 2014, 07:59:52 PM »
 Here is the new OWB
2000 Square Foot Model
       $2,799 Out the Door
The 2000 model firebox size is 30" x 37" with a door size of 18" x 18" and the stove weighs around 1200 pounds.  The 2000 is a good size for a smaller house or shop.  It circulates about 80 gallons of water.  The fire box and water jacket are both built of heavy 3/8" thick steel.
03 Duramax 72000 Miles
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
« Reply #17 on: January 21, 2014, 05:38:03 AM »
My boiler guy has no idea how to make the zone valves and pump turn on.
Does any one have suggestions?
There are three zones, with there thermostat.
Please help!
Wissel sorry I missed this post, the thread seems to have been hijacked, do you still need help on this?
« Reply #18 on: January 21, 2014, 07:30:54 AM »
What kind of actuators do you have on the zone valves?
I have an entire Uponor system for heating system and controls; this is the Zone Control Board I have:
http://www.pexsupply.com/Uponor-Wirsbo-A3031003-Three-Zone-Control-Module
They also make a 4 zone; pretty simple to wire Thermostats in top (2 or 3 wire); 24v Actuators off bottom.
This will not turn the pump on and off just the zones
However, add this: http://www.pexsupply.com/Taco-SR501-4-1-Zone-Switching-Relay ;and use the end switch on the Zone Control Board in place of the thermostat connection in the relay
wissel12
  • OWF Model: 7500
« Reply #19 on: January 21, 2014, 08:40:19 AM »
Slimjim yes I need help.  I did some digging and found a post from October.  It seems the same as my
problem. This is what you posted:
"A Honeywell 1018-6006C strap on aquastat can be used on the incoming wood boiler line, (copper or black iron ) to interupt B-1, simply install the aquastat on the incoming wood boiler line, set it at about 160 degrees, attatch two wires to the R+B terminals on the aquastat and run them down and interupt the B-1 wire, this kills the burner above the setpoint on the aquastat and when the wood boiler temp drops below setpoint of the aquastat the oil/gas burner returns to normal. "
If i unhook B-1 the boiler willn't fire correct?  And if i add the aquastat it will be and back up?
Does the aquastat go into the water with a tee?
Thanks
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
« Reply #20 on: January 26, 2014, 07:20:20 AM »
Solved with PM.
