Author Topic: heating dhw ?  (Read 8432 times)
3roofmen
  • OWF Brand: homemade
heating dhw ?
« on: January 20, 2014, 04:25:58 AM »
will a 10 plate exchanger 5x12 (1 inch ports) heat my dhw ok, and will it cut down the flow from the owb very much ? and I do have well water, I have already ordered one off ebay
« Last Edit: January 20, 2014, 04:52:10 AM by 3roofmen »
Re: heating dhw ?
« Reply #1 on: January 20, 2014, 04:58:26 AM »
A little late to ask now is't it,  yes it should heat it fine, yes it will reduce flow unless you make it a secondary loop, install unions for changeouts, purge tee's and ball valves on all 4 ports for easy cleaning with coil cleaner.
3roofmen
Re: heating dhw ?
« Reply #2 on: January 20, 2014, 05:09:32 AM »
thanks for the reply......yes I should have ask before ordering it but was going to return it and get a bigger one if ya'll thought it would'nt work good, thanks michael
Re: heating dhw ?
« Reply #3 on: January 20, 2014, 08:08:25 AM »
What is the total length of your loop and what size pump do you have? It is very likely you will get really low return temps to the boiler because of the reduced flow unless the pump was way oversized.
3roofmen
Re: heating dhw ?
« Reply #4 on: January 20, 2014, 04:59:59 PM »
total length is 200 ft, pump is a b&g nrf-22
Re: heating dhw ?
« Reply #5 on: January 20, 2014, 09:38:38 PM »
So 100' each way? You will most likely have to add another one in series to use the 10 plate or get a larger pump.
If it is 200' each way you will need a larger pump for sure.
If you go up to a 20 plate you can probably stay with the pump you have for 100' each way.
3roofmen
Re: heating dhw ?
« Reply #6 on: January 20, 2014, 11:03:03 PM »
ok thanks  :)
oldchenowth
Re: heating dhw ?
« Reply #7 on: January 30, 2014, 04:39:52 AM »
I went from a 10 plate to 30 plate.  I did notice a reduction in pressure.  But, I also only have a 2" well.  so just looking at 2 faucets on at a time reduces pressure.  I am happy with the upgrade.  It might just be mental, but I think I regained original flow.
