Author Topic: My 5036 appears to burning a lot of wood at night  (Read 8156 times)
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« on: January 25, 2014, 05:36:30 AM »
This is the first year that Ive had the boiler burn completely out overnight, that Ive had to reload/relight it in the morning we have had a lot of cold morning's 5 and 6 degree's which might be my problem. I think my wood that I have might be getting overly seasoned burning up very quickly. Im going to try to find some greener wood to mix in with my very dry wood. :-\
New Holland TC30 tractor
powerdiver6000@aol.com
MattyNH
  • OWF Model: 7300E ; S-275
Re: My 5036 appears to burning a lot of wood at night
« Reply #1 on: January 25, 2014, 11:57:13 AM »
What type of wood are your burning?
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« Reply #2 on: January 25, 2014, 03:56:03 PM »
Ive got poplar and some overly seasoned oak, Im going to try to find some green oak or not overly seasoned very dry, I ran out of my other wood a couple of weeks ago Im going to top it off tonight maybe at 830pm Ive got my heat pump set to come at 67 degree's. :(
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #3 on: January 25, 2014, 03:58:37 PM »
What is your heat load like?
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« Reply #4 on: January 26, 2014, 06:50:15 AM »
Im heating a 2300 sq ft house and also my hot water, have thermostat set at 73 degree's I loaded the boiler last night a little different than I have been I put wood in vertically in front of the load of wood that I would normally have. It was 20 outside this morning verses 17 degrees the day before but I still had some wood left and the house was still 73 degree's I dont know if it was because of the little extra wood that I placed vertically or the slightly higher outside temp. Ill update later this week when we get our next cold wave to come through. :)
patton acres
  • OWF Brand: central boiler
  • OWF Model: 5036
    • Garden Tractor Salvage Yard
« Reply #5 on: January 26, 2014, 10:47:16 AM »
Here is a thought to consider. I have been having trouble also and I think mine are more the thermostat (see other thread) but last couple days I have tried something. My  5036 faces south .we have had really cold single didget temps and high winds almost non stop. I started leaning the wheelbarrow standing up to shield the door and it seems to have helped a lot. I think its just pushing my heat right out the chimney.
fireboss
  • OWF Model: 6048
« Reply #6 on: January 26, 2014, 01:16:19 PM »
I have a fan on mine and having no trouble with this cold winter,  I can't see the heat going up the chimney !
loneryder
  • OWF Model: 5036
« Reply #7 on: January 26, 2014, 05:06:11 PM »
Poplar does not last very long.  I burn it during the day and save the oak for night burning. You might try that.
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« Reply #8 on: January 26, 2014, 05:28:53 PM »
Thanks for the info I might try putting something in front of the damper we have had some very windy day's up until this morning when I woke up, Im going to get me some greener oak this week even if I have to cut a tree down. :thumbup:
Ryan L
  • OWF Model: 5036
« Reply #9 on: January 27, 2014, 12:11:22 PM »
 I second patton acres reply with the wheelbarrow idea, works great for me reguardless of wind direction, if its windy i am in the habit of putting it against the door, but as they said wood quality is very important, I'll burn what cottonwood, poplar, and junk i have on the warm days and the ash, oak, and maple for the -40 deg. windchill nights and days,i get longer burns and bad azz coal beds! just what works for me?! keep tryin diffrent things good luck!
woodywoodchucker
  • OWF Brand: cental boiler
  • OWF Model: classic 5036
« Reply #10 on: January 28, 2014, 12:25:38 AM »
Its been cold for sure. How long are you cutting your logs? First couple of years I cut mine 30/36 ". Over the last few yares Ive been cutting the logs 18/20" and it seems to burn longer.I think it keeps the flame on the inside of the baffle at the back of the fire box.
Hey Fireboss,I have a blower and put a switch on it and hardly ever use it. In the bottom of the cover I drilled 5 1" holes so I could use it as needed. Did you ever use the furnace without the blower?
  Im interested in knowing what kind and how seasoned is the wood your using with the fan.Ive found that beech and maple burn great if cut and seasoned for 3/6 months.I cut it about 20' and just crack it with a small electric wood splitter.
