Author Topic: Frozen line  (Read 11088 times)
allis48
  • OWF Brand: natures comfort
  • OWF Model: ncb250
Frozen line
« on: January 30, 2014, 08:25:12 PM »
I am looking for an idea on how to fall out the frozen water supply line that is underground?
wissel12
  • OWF Brand: Ridgewood
  • OWF Model: 7500
Re: Frozen line
« Reply #1 on: January 30, 2014, 08:30:25 PM »
What is the water line made of.
03 Duramax 72000 Miles
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
Re: Frozen line
« Reply #2 on: January 30, 2014, 09:07:59 PM »
I use a radiant mat covered by heat/earth blankets, fire up the boiler and thaw away.
But for something small, I've used isopropyl , a strong acid and then flushed very well, just like when we clean a well point or screen, heat tape, the good stuff not depot special.  I have also used steam by torch and compressor. Lots of pipe thawing and repairs last 3 weeks here. How much is frozen, is it boiler pex or yard hydrant.
Michigan Thumber
allis48
  • OWF Model: ncb250
Re: Frozen line
« Reply #3 on: January 31, 2014, 04:09:45 AM »
it runs water from house to the building, the building is heated but I think it froze either where it leaves the house or more than likely where it enters the building. Suppose to warm up tomorrow so hopefully I can get it thawed
It is plastic water line
ITO
  • OWF Brand: HS1
  • OWF Model: 555
Re: Frozen line
« Reply #4 on: January 31, 2014, 05:24:38 AM »
 I had a plastic water line that froze in a rental years ago and I flushed the line with hot water from my water heater by putting a garden hose inside the 1" pipe that was froze, I put the garden hose down the pipe until I felt the block (ice) then turned on the hot water and let it run for quite a while, removed the garden hose and when I turned on the house pressure it blew the chunk of ice out of the 1" line. I probably got lucky and maybe this won't work for you but it worked for me once and it didn't cost me anything (but time) and saved a lot of headache.
 Can see where there will be lots of frozen pipes this year. Good luck.
Re: Frozen line
« Reply #5 on: January 31, 2014, 06:08:07 AM »
Ito has the best solution if yo can disconnect the water line!
allis48
  • OWF Model: ncb250
Re: Frozen line
« Reply #6 on: January 31, 2014, 02:13:54 PM »
I got it this morning!! I put the space heater on hydrant, got it good an warm then blew compressed air back threw it a couple of time ;)
Sprinter
  • In the long run
Re: Frozen line
« Reply #7 on: February 01, 2014, 10:06:51 AM »
Nice, you said it was a hydrant, as in yard hydrant. Sometimes the weep hole where it's supposed to drain gets plugged. At the farm I just pull the head and pressurize the riser and it will blow out the weep, you have to have shaft in down position to open the weep valve.
Michigan Thumber
allis48
  • OWF Model: ncb250
Re: Frozen line
« Reply #8 on: February 01, 2014, 06:24:55 PM »
Yes yard hydrant. I put that in before building was heated, since it has been heated I never turn it off so the seal wouldn't go bad since the genius cemented around it. But the -24 below froze it up .
