Author Topic: Forced draft over fire or fan under the fire  (Read 7652 times)
harley
« on: February 09, 2014, 10:03:54 AM »
It would seem to me that if you have a ash or hot coal build up in bottom of the fire box it would be hard for the fan to force air up through the grates  from the bottom of the fire box so over the top of the ash would burn better and hotter.
Re: Forced draft over fire or fan under the fire
« Reply #1 on: February 09, 2014, 10:08:11 AM »
nope, opposite is true
Unless u simply let ur ash get packed in there and never stir it
When it comes up through the coal bed it gets hot and intensifies the burn making it burn hotter and cleaner
Thats not to say that a forced fan through the door doesnt Work because it does, but there is an advantage to it coming up through the coals...
mtoll
« Reply #2 on: February 09, 2014, 10:15:32 AM »
So it better to stir the top draft it little more often
Wife Rodeos, have 5 Barrel racing horses
Ride HD Road Glide
Vet  USN / USMC
« Reply #3 on: February 09, 2014, 10:19:57 AM »
yea with any stove once your coal bed gets fairly deep its good to give it a quick stir once a day.
One advantage top draft has is that if folks get lazy and dont keep ash loosened up that it always burns the same.  For example if u have below grates air coming in and only have a 6 Inch spot in grate thats open all air will wanna come up through there, either will work and work well though
racnruss
« Reply #4 on: February 10, 2014, 11:28:16 AM »
some stoves have both!
Marktk
  • OWF Model: Mf5000
« Reply #5 on: February 11, 2014, 11:25:08 AM »
Have both would be the ideal setup im assuming? Could a guy add over the fire air easily enouhg?
racnruss
« Reply #6 on: February 11, 2014, 12:30:32 PM »
With some fabricating skills, anything is possible.  Heatmaster has some models with over and under air.  In your case, maybe some sort of scoop in the back of the firebox that extends down into ash area to catch some of the air blowing in and directing it up into back of firebox above the fire.
