Pages: 1 [2] 3
Author Topic: Coal vs Wood  (Read 20426 times)
d conover
  • OWF Model: H4
Re: Coal vs Wood
« Reply #15 on: February 11, 2014, 07:47:03 AM »
Where would a person buy coal in South East MO?
I know my dad talks about burning coal as a kid.  But I haven't seen any coal for sale around here.
Southeast Missouri
Hardy H4
044 Stihl
038 Stihl
5100s Dolmar
55R husqvarna
CS301 Echo
artbaldoni
  • OWF Brand: Nature's Comfort
Re: Coal vs Wood
« Reply #16 on: February 13, 2014, 11:58:21 AM »
Update.
Still dialing in. The problem is that the coal fire goes out at idle. No work today because of the snow so I have a chance to experiment. I have the damper flap closing on a peice of 10 ga. wire leaving a small gap to allow some constant air. Fan has been off for several hours now and the temperature is VERY slowly dropping and there is still a nice orange glow in the coal. Waiting for the fan to come on to see if it picks up. If this setting works I forsee getting incredibly long burn times running coal.
May have to start selling the wood I cut and buying coal!
Nature's Comfort  NCB-175
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
Bobcat 7753 w/EEL Tracks
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
andyhowardcity
Re: Coal vs Wood
« Reply #17 on: February 13, 2014, 05:30:32 PM »
update art?
Timberwolf 5000 (Installed 9/2013)
Sidearm heat exchanger (in process of being installed)
20 cords of hardwood and 10 of soft ready to go :)
Stihl MS 362
Fiskars X27
artbaldoni
Re: Coal vs Wood
« Reply #18 on: February 13, 2014, 06:43:27 PM »
Fire got too low before the fan came on. Went out or would have if I didnt tend it and add a couple pieces of dry wood. Readjusted the "constant air" a little more open. Blower is now off and temp has climbed to 200+°. Watching carefully to make sue it does not boil. It should start to  drop soon. Maybe the fan will never come back on until morning.
I've made about 30 trips to the basement, out to the boiler, back to the basement and back up the steps. That's just about enough for today!
May need a cycle timer for the blower.
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
Re: Coal vs Wood
« Reply #19 on: February 13, 2014, 07:11:33 PM »
How about tightening up the differential a bit?
Re: Coal vs Wood
« Reply #20 on: February 13, 2014, 09:03:08 PM »
What you're describing is what a lot of company's dealt with trying to get shelled corn to work as a fuel for OWB. We had a Wood Master dealer right in town that had one of the first prototypes for a corn boiler, what a pain. Corn has to be mighty cheap to use as a fuel when wood can be had.
I messed around building one as well. Just built the fire pot to play with. A vertical pot force fed from the bottom burned the best, but was harder to light and maintain a fire during idle times, was also very finicky about fines in the corn, moisture and any broken kernels.
A horizontal fire pot was easier to fab up. Used one gear motor to turn the stirrer very slow, like 3-4 rpm. Corn burns incredibly hot, kept burning up the stainless steel I used for an agitator. Went with a piece of 3/4 pipe instead, drilled a 1/4 hole in it then welded a piece of 1/4" stainless pipe over the hole then forced air thru the 3/4" pipe to cool the stainless. That worked better, one motor for the agitator and another motor to feed corn separately with a on/off delay. Still couldn't keep it lit during idle times, would burn fine all day, but might or might not like an hour of idle time. Finally bought an electric pencil torch off the net, pump a certain cfm of air thru that and end up with 1500 degrees at the tip, used a set of timers to fill with fresh corn, then so much time on the electric torch, then the agitator and fuel feed. Worked like a charm, then corn went up enough that we could actually make money on it instead of losing money as soon as the seed went in the ground, whole thing is still back in the scrap pile.
Your ideal of a cycle timer for the blower sounds promising, might want to add a second high limit so if it does get around 200F it doesn't cycle.
« Last Edit: February 13, 2014, 09:07:47 PM by mlappin »
artbaldoni
Re: Coal vs Wood
« Reply #21 on: February 14, 2014, 04:43:40 AM »
Slim, diff at tight as it gets, 5°. Just a no frills Honeywell a-stat.
Was awake most of the night with back spasms and didn't hear the oil kick on at all. Fought the urge to go look at the boiler until about 0530. Found a 6" deep, nicely burning coal bed, fan on, 175° water temp. This means that the boiler ran through at least 1 cycle since the fan was off when checked last night around 2100.
Turned the fan off, ran the poker along the grate under the coal bed to clear the ash, added 5 coal shovelfuls of wet stove size coal and turned the fan back on. Now I wait to see if it takes off.
Stay tuned, same coal time, same coal channel!
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
Re: Coal vs Wood
« Reply #22 on: February 14, 2014, 07:34:00 AM »
You might try the Jonson A-419 aqua-stat controller, I'm running mine with a 1 degree differential on my chip boiler right now and it's set at 202 degrees F
andyhowardcity
Re: Coal vs Wood
« Reply #23 on: February 14, 2014, 05:27:53 PM »
Sounds like it is going to be doable but tricky (Ï'm thinking boil over is likely in warmer weather)
Stihl MS 362
Fiskars X27
MW
Re: Coal vs Wood
« Reply #24 on: February 14, 2014, 08:12:36 PM »
If your burning soft coal like run-of-the-mine or the larger nut coal you should be able to get about 10 - 15 degree differential.  The biggest problem with burn times will be the coal burns up through until the blower motor doesn't have enough force to burn any higher.  When burning coal I kept the flap open about 1/8 to 1/4 inch so the coals stayed to refire.  Never burned hard coal, but guys I know did said it can be more problematic to get reigniting.
artbaldoni
Re: Coal vs Wood
« Reply #25 on: February 20, 2014, 03:46:10 AM »
Thanks slim. Will be putting one on this weekend. I had looked at Ranco but it looked like it was only 3° diff. Glad to find the A-419.
Also got some bituminous nut size coal yesterday. Mixing it with anthracite stove size. Stayed fired all night.
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
mtoll
Re: Coal vs Wood
« Reply #26 on: February 20, 2014, 05:59:32 PM »
Let us know how the bituminous does
Wife Rodeos, have 5 Barrel racing horses
Ride HD Road Glide
Vet  USN / USMC
artbaldoni
Re: Coal vs Wood
« Reply #27 on: February 20, 2014, 06:28:14 PM »
This bit is the shiz! Have had fire since yesterday at 1600. No problems. I put 3 pieces of wood in the boiler yesterday to get the coal mix started, have not put any wood in since. 100% coal burning well at 45° ambient, which means lots of idle time. No trouble refiring. Have tended/loaded 2 times since original fire. This will take me through tomorrow morning or maybe afternoon.
I will still burn wood beause I have so much available to me but I am sure liking the coal right now. We'll see how long the infatuation lasts...
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
artbaldoni
Re: Coal vs Wood
« Reply #28 on: February 23, 2014, 10:25:43 AM »
Update:
Johnson A419 installed today. Had to run a neutral wire to the A419. No big deal.
Temp set at 175°, diff at 2°. Damper full closed, no constant air. We'll see how that works.
Fan cut off at 175° just like it was supposed to. Temp climbed to 179° and seems to be holding.
Will check later to see if its has dropped.
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
rick n kristi
Re: Coal vs Wood
« Reply #29 on: February 24, 2014, 01:42:29 PM »
You are on to it! $75 a ton in my neck of the woods for bit coal. Have burned about 2.5 tons this winter!
Natures Comfort 325G
Still 038 magnum
Pages: 1 [2] 3
