Pages: 1 2 [3] 4
Author Topic: G100  (Read 41364 times)
Re: G100
« Reply #30 on: February 28, 2014, 10:06:49 AM »
Scott, Max BTU output is 120k for the g100 correct? That means that if you heated a large heat store, say 500-1000 gallons for 4 hours wideopen at 120k per hour you would store 480k btus or somewhere about that? Home that requires 50k btu per hour would last 10 hours + on that heat store? 50k btu is pretty high for a heat load correct?
Re: G100
« Reply #31 on: February 28, 2014, 10:07:14 AM »
Gassers need a good coal bed to burn cleanly. The first few hours of a new fire you do not get a good burn. I'm not sure large storage with a burn once a day will be the answer.
Re: G100
« Reply #32 on: February 28, 2014, 11:13:43 AM »
We all agree that the amount of btus needed is the same regardless correct? If the burner needs to run 6 full hours to store enough btu to last 24 hours then you run one full firebox then a half a firebox. This keeps you from needing to load every 8 hours.
Re: G100
« Reply #33 on: February 28, 2014, 11:24:45 AM »
Yes the fire boxes are small to make them cleaner to pass the darn epa test, was speaking with a guy about it this morning
In regard to batch burning, it wouldn't do much good to add more storage to this unit,  it's not possible for it to hold any more wood so if you did have storage it might rub wide open for 4 hours, but then you need to reload it so what does that accomplish?   Nothing in my opinion
Not to derail the thread (much) but if a person was building their own and damn the emissions the fire box could be larger and not affect the gasification process?
I don't mind twelve hour burn times, the one I built will run much longer if you fill it, but seems more efficient if I load for 12 hours at a time. Load it up at night, then check in the AM and adjust the amount i add. If it's warmer out I may leave it go to burn the coals down and get ahead of the ashes.
« Last Edit: February 28, 2014, 11:30:17 AM by mlappin »
Re: G100
« Reply #34 on: February 28, 2014, 12:13:39 PM »
 I guess you could discuss that with the EPA after the regs pass.  ;D
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: G100
« Reply #35 on: February 28, 2014, 12:21:38 PM »
"We have to pass it to know what's in it."  - Nancy Pelosi
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
Re: G100
« Reply #36 on: February 28, 2014, 12:49:27 PM »
Maybe I misunderstood what I heard somewhere else or it was just false, but I thought homebuilt were exempt.
Re: G100
« Reply #37 on: February 28, 2014, 01:40:20 PM »
 I have no idea, I didn't see that when I read it but then again I wasn't looking at it. Legal or not I feel certain there will be plenty of homemade ones out there after people can't buy what they want next year.
Re: G100
« Reply #38 on: February 28, 2014, 02:21:21 PM »
Honda racer,  my numbers were just in theory
With a stove that gets these kinds of numbers and emissions down to .07 vs most gassers at .32
There isn't a lot of room for improvement during the down time in my opinions.
Look at some garnish customers, I know a few, even with 1500 - 2000 gallons of storage this winter a lot of them are firing twice per day..  I donno about you but I don't like building a new fire and going through the kindling process.  I'd rather load and forget it
I just don't see where u think all the extra btu will come from,  let's look at it like this for example.
5 cubic feet of wood, let's say it weighs 40 pounds
Moisture content is 20%
That means 344K btu, instantly reduced to 275k btu by moisture content
Now if the furnace can capture 80% of what's left.
We are down to 220k btu of actual usable heat
If our heat load is 30 btu per hour,  u got about 7 hours worth
If you could put those 7 hours in a tank u r still out of wood.
Now it may hold more than 40 pounds depending on the type and how it's cut, but those numbers were just rough ideas
I know when I ran the XT100 the firebox was very small
mtoll
Re: G100
« Reply #39 on: February 28, 2014, 03:18:13 PM »
Scott7m, what kind of cost on the new G units
Wife Rodeos, have 5 Barrel racing horses
Ride HD Road Glide
Vet  USN / USMC
Re: G100
« Reply #40 on: February 28, 2014, 04:53:36 PM »
G100-$7,500 G200-$9,500
mtoll
Re: G100
« Reply #41 on: March 01, 2014, 07:27:41 AM »
In 2015 do I under stand you will only be able to buy G models or can you buy the 350,000 plus btu models
Ride HD Road Glide
Vet  USN / USMC
Re: G100
« Reply #42 on: March 01, 2014, 07:49:18 AM »
The latest and most credible info I've seen says there will no longer be a btu loophole as there is now in certain states
mtoll
Re: G100
« Reply #43 on: March 01, 2014, 08:52:58 AM »
Scott7m Thats interesting
Ride HD Road Glide
Vet  USN / USMC
Re: G100
« Reply #44 on: March 01, 2014, 04:50:31 PM »
 The info I've see will not allow large furnaces of any kind. Unless its changed there is a cap that large gassifiers will not even be able to meet. Scott, is that the way you read it?
Pages: 1 2 [3] 4
