Author Topic: Water to air fin coil & flat plate heat exchanger specification charts  (Read 5301 times)
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
Here are a couple links on BTU output, GPM flow, cfm flow , water temp, size and sizing info for calculating , planning or those who don't have labeled exchangers to get an idea on what you have.
http://www.firstco.com/getattachment/Products/Multi-Family-Residential-Products/Miscellaneous/HWC/hwc209.pdf
http://www.brazetek.com/finned-coil-water-air-heat-exchangers
Both have flat plate data sheets as well. If anyone finds more info please add
Michigan Thumber
Sprinter, how the heck do you find all this stuff and then how do you comprehend it!
Sprinter
  • In the long run
Bump the spammers
« Last Edit: June 05, 2014, 05:54:12 AM by Sprinter »
Michigan Thumber
Sprinter
  • In the long run
Bump the spammers
Michigan Thumber
