Author Topic: Fire Box Tools For Your OWB  (Read 29803 times)
browncty
  • OWF Brand: American Royal
  • OWF Model: 7400B
« on: March 09, 2014, 09:31:28 AM »
Well I have a question for everyone about the tools they use to move the ashes around, stove pokers or whatever you call them. I currently use a long steel rod to adjust the wood and poke the ashes to help them settle. I also use a shovel to adjust the ashes which I realize will not last long with a wooden handle. I use the shovel to move the ashes around. I was thinking of using a rack but then you there's the wooden handle.
I have not done much research online into sites that might sell wood boiler accessories like this. I have friends that have made tools to bring the ashes to the front or to rearrange the ashes. My firebox is is really deep and I tools at home to make something. Is they a site that sells these types of tools or do I need to have one specially made? Any help would be appreciated.
cantoo
  • OWF Brand: Western Pacific
Re: Fire Box Tools For Your OWB
« Reply #1 on: March 09, 2014, 11:02:12 AM »
I made a couple of my own using 3/4" steel pipe and a piece of flat bar 3"x 8" long welded onto the end. One is about 5' long and the other is 8' long. I also use a wooden handled rake because it's warmer on the hands than the steel.
browncty
  • OWF Model: 7400B
« Reply #2 on: March 09, 2014, 11:24:08 AM »
cantoo, did you use stuff you had on hand or scrap to make it. I do know someone who weld me something like that and sounds like it works well for you.
tawilson1152
  • OWF Brand: Crown Royal
  • OWF Model: 7300
« Reply #3 on: March 09, 2014, 01:28:54 PM »
I picked up a masonry hoe at Lowes last fall that has held up well.
BoilerHouse
  • OWF Brand: Home Built
« Reply #4 on: March 09, 2014, 03:10:49 PM »
I welded up a shovel to remove the ashes.  It was custom made from steel odds and ends lying around and sized to just fit through the ash door.  A welding shop could easily make something up for you if you have a basic idea of what you would like.
Muskoka, Ont
Michael
  • OWF Brand: Tennessee Outdoor Furnaces
  • OWF Model: 400 HE
« Reply #5 on: March 09, 2014, 04:58:40 PM »
Mind came with a custom hoe to pull the ashes out from under the grate into a wheelbarrow or loader bucket. Works great. I use a long board to help slide in large pieces.
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
« Reply #6 on: March 09, 2014, 05:04:55 PM »
I had a friend of mine that's a tool maker make me a custom hoe.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
« Reply #7 on: March 09, 2014, 05:58:57 PM »
My Heatmor came with a scraper for the rectangular portion of the chimney that is a 4' long rod with a rectangular plate welded to the end.  The rod is centered in the plate.  It works well for moving wood around and scraping ashes into the shaker grate area.  For moving larger chunks of wood or awkward things, I keep a pair of firefighting gloves on the shelf in the boiler.  My wife wears them all the time to load the thing, but I only put them on to pick up burning wood.  When they wear out, I take them back to work and get them replaced for free since that's what I do for a living  :thumbup:
baldwin racing
« Reply #8 on: March 11, 2014, 05:56:38 PM »
I took a olf flat shovel with broken wooden handle cut a piece of pipe the length I wanted it and welded it where the wooden handle was....I also weld another short piece probly 4-5 inches long at end....so its a t....so you can hang it up as well...... For a scrapper to scrape ashes and coals forward.....I also took a piece of 1/8 plate 3 inches high and 5-6'' wide welded a rod to that as well,I also put two braces one from each corner of plate back to rod for support......I  welded 4-5 inch piece of pipe on the end for a t to hang up as well.... simple and they work well.....if you want pics let me know
Kelly
husqvarna 357 xp
farmall H
glock_556
  • OWF Brand: Earth
  • OWF Model: Woodsman 405
« Reply #9 on: March 11, 2014, 08:39:15 PM »
Maybe I'm simple, but I just use a regular old shovel
SE Missouri
Stihl MS362CM
Brave 22 Ton splitter
« Reply #10 on: March 11, 2014, 08:41:50 PM »
me too...i have an old shovel with a wooden handle and an old hoe with a wooden handle for pulling coals forward and scraping the fire box wall....the how is the original (13 or 14 years old) haven't burnt it away yet ;D
« Reply #11 on: March 11, 2014, 08:46:29 PM »
I use a garden claw. It works really well to bring the unburnt pieces to the surface so they can burn up completely. It has a pipe welded on instead of the original handle.
Bluegrass Wood Burner
  • OWF Brand: Ozzark Biomass
« Reply #12 on: December 10, 2016, 08:28:22 PM »
I use a garden rake and a hoe with the claws.
South central Kentucky
Ford F-150
16 ft tandem trailer
3000# winch
Husqvarna 142
Husqvarna 460 rancher
6ft spud bar
Poulan 3314
22 ton lowes splitter
Timberline sharpener
"Worn out body"
« Reply #13 on: December 11, 2016, 07:15:28 AM »
I'm sorry folks. Didn't realize how old this topic was. Me being an old man I got bored and started reeding some old post and responded before I caught the date. You all overlook me.☺️
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
patvetzal
  • OWF Model: ML36
« Reply #14 on: December 11, 2016, 12:10:08 PM »
Even an old boiler needs tools to keep it efficient.
We bought our P&M second hand so it came with nothing. An email to the factory resulted in some measurements to make a hoe that would work for creosote and a poker/puller evolved out of an 8' piece of re-bar...
