Author Topic: Major temp loss with new install  (Read 16249 times)
Re: Major temp loss with new install
« Reply #15 on: March 10, 2014, 08:38:14 AM »
 A pump moving the water slowly could cause the flat plate to really pull it down before it got to the coil in the duct.
« Reply #16 on: March 10, 2014, 08:42:12 AM »
Great point Yoder.
bajonesy77
  • OWF Brand: Prosteel
  • OWF Model: 200
« Reply #17 on: March 10, 2014, 09:13:45 AM »
Just to verify your stove is 150ft outside + 75ft in home to your hx? So 225ft each way for a total of 450ft round trip? What size plate exchanger? Definitely sounds like a low flow/air lock problem.
Brave 22 ton splitter
Stihl 440 magnum 20" bar
Stihl 390 20" bar
Wi woodburner
  • OWF Brand: Woodmaster
  • OWF Model: 5500
« Reply #18 on: March 10, 2014, 01:12:40 PM »
I taped a thermometer to the pex at several areas inside the house.  All readings were basically the same as the Ranco temp display which is still 20 degrees cooler than the reading at the stove.  Today I am going to do this outside by the boiler to see if the heat loss is happening from the stove to the house.
As far as air in the lines, would I be safe to open the valve and run water out the top of the vent to know it is full of water?
ITO
  • OWF Brand: HS1
  • OWF Model: 555
« Reply #19 on: March 10, 2014, 03:20:37 PM »
If you have a valve and vent after the pump open the valve slowly with the pump running and see if it puts any air out, you should be able to hear it purge any air if it's in the line, you will most likely hear the water fill the line as well. Just curious, where about are you in WI? I'm in NW corner of the state.
« Reply #20 on: March 10, 2014, 06:22:13 PM »
Sure sounds like an airlock to me!
« Reply #21 on: March 10, 2014, 08:28:26 PM »
 Yea if you tape it to pex you will be 20 degrees off, pex just doesn't transfer heat as well as copper. After you tape it to the copper inlet of your coil you also need to insulate it.
« Reply #22 on: March 10, 2014, 10:11:49 PM »
 :post:
