Author Topic: Hydronic fundamentals, lots of info  (Read 5669 times)
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
« on: March 26, 2014, 10:40:16 AM »
Calefi idronics #12 hydronic fundamentals, lots of useful bits of info
Page
5 how radiant works/heats, benefits vs other heating types
15 system components and how they work together
22 boiling points, static pressure, air in fluid
30 circulator flow in heat loops, hydraulic separation between loops
39 heat pump applications, water to water, air to water
51 thermal equilibrium and why/how every system achieves it
55 low temp radiators and high temp
66 zoning, ZV& circs, primary secondary examples, series versus parallel designs
75 balancing, variable temp control, low mass, adding mass, high mass
85 mixing fundamentals
http://www.caleffi.com/sites/default/files/file/idronics_12.pdf
Michigan Thumber
idahohay
Re: Hydronic fundamentals, lots of info
« Reply #1 on: March 26, 2014, 11:29:51 AM »
Good information for sure. Wish I had all the hard copies instead of downloads.
Sprinter
  • In the long run
« Reply #2 on: April 10, 2014, 02:56:33 PM »
If you sign up, you'll get the new ones. I think you can request back issues
Michigan Thumber
Sprinter
  • In the long run
« Reply #3 on: June 05, 2014, 05:55:41 AM »
Bump
Michigan Thumber
