Author Topic: Stainless Steel Manifolds and Circ Pumps  (Read 12232 times)
« on: April 25, 2014, 07:56:58 AM »
For those who have experience aand/or installed systems, could you please recommend manufacturers and models of stainless steel recirculation pumps and manifolds for radiant floor heat?  :-\  (Note: this will be an open system installation).
I just am fishing for what to look at and have no intention of starting a Ford vs. Chevy debate.
I just want to compare what is "out there."
Thank you for leads, links, and suggestions.  :thumbup: -Sloppy
« Last Edit: May 05, 2014, 08:18:20 AM by Sloppy_Snood »
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: Stainless Steel Manifolds and Circ Pumps
« Reply #1 on: April 25, 2014, 09:45:32 AM »
Take a look at the Grundfos Alpha I believe the run about $250 for the stainless but you should eventually get your money back on your electric bill.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
« Reply #2 on: April 26, 2014, 04:17:33 AM »
Taco has a nice prefab manifold, get the one with flow meters and valves already installed and ask the supply house to help you with the layout, manufacturers sell them, the supply house knows the application in the field.
Jwood
« Reply #3 on: April 26, 2014, 05:12:44 AM »
Rehau has some really nice ones as well that's another option
Rehau Pro Balance
I actually have a 3 circuit pro balance that I don't know what I'm going to do with ( I need a five for my basement ).
Stihl MS 270c
Stihl MS 461
« Reply #4 on: April 26, 2014, 05:19:31 AM »
How about tying 2  three loops together and have a spare
Jwood
« Reply #5 on: April 26, 2014, 05:57:46 AM »
The Rehau can be hooked up in series like you are saying slim the price for a 3 circuit and 5 circuit are not that far apart so I figured if I could sell the 3 circuit then I'd be better off
Stihl MS 270c
Stihl MS 461
Jwood
« Reply #6 on: April 26, 2014, 06:14:45 AM »
Here is what I have
Stihl MS 270c
Stihl MS 461
« Reply #7 on: April 26, 2014, 06:22:33 AM »
Ok, nice manifold, for anybody interested, how much?
Jwood
« Reply #8 on: April 26, 2014, 06:27:33 AM »
If someone wanted to give me 100 bucks that would work for me.
Stihl MS 270c
Stihl MS 461
« Reply #9 on: April 26, 2014, 06:33:09 AM »
That would make somebody a good deal!
Jwood
« Reply #10 on: April 26, 2014, 06:36:39 AM »
Ya that would make it worth it to someone maybe
Stihl MS 270c
Stihl MS 461
« Reply #11 on: April 28, 2014, 07:05:53 AM »
Do you need a SS pump?  Cause if you don't you can save a small pile of $$$ on pumps
« Reply #12 on: April 28, 2014, 04:48:03 PM »
My Grundfos cast iron was still working just fine this winter when I changed it out to play around with a Taco Delta T pump. Took it apart even, no noticeable corrosion.
« Reply #13 on: May 04, 2014, 10:40:05 AM »
Mainly because mine will be an open system.  I'll pay the $$$ premium for stainless steel. ;)
« Reply #14 on: May 05, 2014, 06:42:43 AM »
I would agree with Jwood, SS Alpha is about the $$ as a 3 speed SS Grundfos -> Alpha might even be cheaper. and with the auto-Adapt you should not be overpumping system.  In regards to manifold, any Brass or stainless steel should work, I think there are even a few plastic manifolds out there (would check temperature rating before I installed a plastic manifold)
Sloppy_Snood, sorry forgot to read initial post, but to my credit you only asked about SS pumps/manifolds did not clearly state OPEN System
