Pages: 1 [2] 3
Author Topic: Rehau  (Read 24083 times)
Rockarosa
  • OWF Brand: Pro-Fab
  • OWF Model: Cozyburn MS 250
Re: Rehau
« Reply #15 on: April 28, 2014, 06:55:00 AM »
Jwood, have you used the Rehau? I'm trying to decide which product to buy and whether I need to run it through schedule 40.
New Holland T C 30
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: Rehau
« Reply #16 on: April 28, 2014, 06:59:43 AM »
No I have not most people on here use logstor due to the true 1" I.D. of the pipe, Rehau may have something similar to that size both are great choices I just believe logstor is a bit better. Others will chime in as well. Scott7m had mentioned something about a better method maybe he will voice it again!
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
Jwood
Re: Rehau
« Reply #17 on: April 28, 2014, 07:02:39 AM »
Oh and the answer to your second question is no you won't need run either through schedule 40 pipe.
Stihl MS 270c
Stihl MS 461
Rockarosa
Re: Rehau
« Reply #18 on: April 28, 2014, 07:18:59 AM »
Jwood, I installed my OWB back in 08, towards the end of last summer after heavy rains I had water come into my basement from the corrugated pex. Man, I burned a lot of wood this winter. From what I have read it would be hard to make any bends through the schedule 40 with the Rehau. On e-bay 100 ft. of REhau is $4.49 a ft. the Badger 5wrap is around $ 6.00 a ft. I have an 80 ft. run and can't afford the Logstar. So am trying to decide which is better.
New Holland T C 30
Jwood
Re: Rehau
« Reply #19 on: April 28, 2014, 07:45:27 AM »
With that price I'm assuming that is not insulpex maybe its their foam wrapped stuff but if it was I'd buy it there is a post under portage and main from Sloppy Snood and in his post on his install he used a new seal, can't remember the name off hand.
Stihl MS 270c
Stihl MS 461
Jwood
Re: Rehau
« Reply #20 on: April 28, 2014, 07:57:38 AM »
Rock- after looking more into the stuff you are talking about I'm thinking this is what you are talking about and I would stay away from that.
Stihl MS 270c
Stihl MS 461
Jwood
Re: Rehau
« Reply #21 on: April 28, 2014, 08:00:23 AM »
This is the good stuff from Rehau and that seal is called link seal.
Stihl MS 270c
Stihl MS 461
Re: Rehau
« Reply #22 on: April 28, 2014, 08:20:58 AM »
In regards to the insulated pipe im installing at home now I am using a 5 wrap product from z supply.
Why?  Conduction of heat, creating barriers for heat to cross vs simply laying in contact with cold wet soil.
In one scenario a guy pulled thermopex through 6 in schedule 40 and saw a 75% reduction in heat loss vs burying it direct
He sealed both ends of the pvc and placed temp sensors inside to monitor it.  With no hear flowing through, his temps ran 47-48, under full load at 180, the air in his "pvc plenum" stayed around 85, creating a barrier to the cold soil.  He said it lost 75 percent less heat.
Why I went with z supply is its great about heat lost but I agree that logstor has tougher casing, so I pulled there 5 inch casing through 6 in pvc, the vapor barrier of z supply is another key factor, ur foam filled products dont have that I just took it a step farther to create another dead air space or pvc plenum for my pipe to run through
Ched Bull
  • OWF Model: mf 5000
Re: Rehau
« Reply #23 on: April 28, 2014, 10:00:40 AM »
JWood the rehau you said was the good stuff is what I used, shewww that was stiff pipe!
Stihl 261c, Home made 36 inch long 27 ton horazontal log splitter, John Deer 2520, 2004 Chevy Four Door Duramax 70,000 miles, Kirksville Mo.
ELVIS1
  • OWF Model: 2000
  • The devil delivers propane
Re: Rehau
« Reply #24 on: April 28, 2014, 10:18:46 AM »
I'm in the process of doing the same thing Scott7m is doing. Z supply looks like quality wrap and running it through the pvc
Would definitely create an air barrier plus keep it all very dry which is the most important thing.
Jwood
Re: Rehau
« Reply #25 on: April 28, 2014, 10:24:34 AM »
Yes Ched bull that is stiff but it was good quality wasn't it? And that first pictured stuff I wouldnt waste my time with it just looks like a cheap alternative. The way Scott and Elvis are doing it sounds like good way as well if using a 5 wrap I wouldnt bury that alone, I'd do what Scott is doing.
Stihl MS 270c
Stihl MS 461
Rockarosa
Re: Rehau
« Reply #26 on: April 28, 2014, 10:26:26 AM »
The nearest  Z dealer is over 100 miles away from me. Still looking at the 5 wrap Badger. How much a ft is the Z plus I would have to pay shipping.
New Holland T C 30
Re: Rehau
« Reply #27 on: April 28, 2014, 11:55:43 AM »
we ship it all over the country....  the insulation is thicker and a higher quality buy your gonna end up maybe 8 per ft with shipping
Rockarosa
Re: Rehau
« Reply #28 on: April 28, 2014, 01:33:08 PM »
Scott, thank you for the response and I will keep thinking and planning this job. Only going to do this one more time. The Logster and Thermoplex are just to expensive for me at this time.
New Holland T C 30
Ched Bull
Re: Rehau
« Reply #29 on: April 28, 2014, 02:57:33 PM »
Yes JWood you are 100% right and by george I believe Scott is on to something, this that Scott is going to do may even be better plus cheaper.
Pages: 1 [2] 3
