Pages: 1 ... 4 5 [6] 7
Author Topic: Corrosion Protection  (Read 59216 times)
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
Re: Corrosion Protection
« Reply #75 on: April 18, 2015, 04:41:37 AM »
Was sold out at 57 binoot$.can]
Napa 25% off
Everybody must be monitoring this forum :o
Ordered one,, pick it up Monday.
« Last Edit: April 18, 2015, 04:43:47 AM by kommandokenny »
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
« Reply #76 on: April 18, 2015, 08:44:33 PM »
well it .......IS NOT going thru a pump sprayer...it is some where between e-vap milk and sweetn condense  ......
kommandokenny
  • OWF Model: 4400
« Reply #77 on: April 19, 2015, 07:27:48 AM »
Crap won't go through a garden sprayer?
Don't have anything else.
Gonna cancel my gallon from napa maybe switch to the spray cans and buy a case.
Or go back to WD40 and put it on in May then again August.
Might be too much fuss over the rust thing.
If It's shut up good and fogged with something should be good enough.
Not livin on the Newfie coastline, with salt spray, coming off the ocean here.
Thanks for the heads up on the Fluid Film.
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
atvalaska
  • 907, no vacancy !
« Reply #78 on: April 19, 2015, 10:47:18 AM »
the stuff smells like Cosmoline .... """"Chemically, cosmoline is a homogeneous mixture of oily and waxy long-chain, non-polar hydrocarbons. It is always brown in color, but can differ in viscosity and shear strength. Cosmoline melts at 113–125 °F (45–52 °C) and has a flash point of 365 °F (185 °C).
Its most common use is in the storage and preservation of some firearms, hand tools, machine tools and their tooling, and marine equipment. Entire vehicles can be preserved with cosmoline."""  >.......................i'm going to heat it up then spray it ...it should really get in the spaces ..then seal up good!
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
« Reply #79 on: April 19, 2015, 11:21:13 AM »
It's oil squeezed out of wool I believe I read that's why its non toxic
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
kommandokenny
  • OWF Model: 4400
« Reply #80 on: April 19, 2015, 03:34:48 PM »
Non toxic is good .
Nice that something natural, is such a great product also.
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
Cabo
  • OWF Brand: P & M
« Reply #81 on: April 19, 2015, 04:59:27 PM »
You may want to look into a Fluid Film spray kit.  It comes with a gun, 3 spray bottles, several tips and a couple of 24"-30" wands.  One of the wands has a tip that sprays thru the sides which is very useful for doing the heat exchange tubes.  Complete coverage of the entire tube.  As I recall the kit goes for about $65 and you would be all set to undercoat your vehicles as well.
atvalaska
  • 907, no vacancy !
« Reply #82 on: April 19, 2015, 05:10:37 PM »
Quote
   I found this > .......dam!!!   I can still learns'me stuffs  :)  .......Crude lanolin constitutes about 5–25% of the weight of freshly shorn wool. The wool from one Merino sheep will produce about 250–300 ml of recoverable wool grease. Lanolin is extracted by washing the wool in hot water with a special wool scouring detergent to remove dirt, wool grease (crude lanolin), suint (sweat salts), and anything else stuck to the wool. The wool grease is continuously removed during this washing process by centrifugal separators, which concentrate it into a wax-like substance melting at approximately 38 °C (100 °F).
Jwood
« Reply #83 on: April 19, 2015, 07:32:49 PM »
Quote
:thumbup:
Stihl MS 270c
Stihl MS 461
kommandokenny
  • OWF Model: 4400
« Reply #84 on: April 20, 2015, 06:54:09 AM »
Good call,,, may work better and cheaper than the Wagner?
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
Bondo
  • OWF Brand: Home built
  • Master General Re-Engineer
« Reply #85 on: April 20, 2015, 03:32:33 PM »
Ayuh,....   This is 'bout what my sprayer looks like,...
Mine's got a 4' hose, insteada the short tube,....
« Reply #86 on: April 20, 2015, 06:45:45 PM »
If you have a siphon wand you can probably use that instead of dropping scratch on a gun
kommandokenny
  • OWF Model: 4400
« Reply #87 on: April 23, 2015, 06:09:16 AM »
Just ordered the gun with bottle off ebay
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
kommandokenny
  • OWF Model: 4400
« Reply #88 on: April 23, 2015, 06:10:40 AM »
Tall rubber boots for catching the sheep ,,,
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
« Reply #89 on: April 23, 2015, 05:48:01 PM »
Don't forget your Velcro gloves. ;)
