Author Topic: Kubota tractor  (Read 4180 times)
Kubota tractor
« on: June 05, 2014, 05:58:18 PM »
Anyone have any experience with the M5640 model, I have a "clicking sound coming from the right front. Does it in 4 wheel and out. Kinda sucks it only has 260 hours on it. Guess I will do a wheel bearing check.
Re: Kubota tractor
« Reply #1 on: June 05, 2014, 06:14:07 PM »
I don't own a Kubota (JD here) but that would have been my guess, check the wheel bearing.  Also could it be a chipped gear?  Just guessing...  Roger
Re: Kubota tractor
« Reply #2 on: June 05, 2014, 06:23:15 PM »
I have been told to tighten the lug nuts, sometime they can make the noise if loose ( cant find my torque wrench). I will check with the dealer also. Might be under warranty.
Re: Kubota tractor
« Reply #3 on: June 05, 2014, 06:37:19 PM »
Of course, the lug nuts.  I completely forgot about them but smart to check warranty.  Post when you find the problem.  I'd be curious to know what it was.  Roger
Re: Kubota tractor
« Reply #4 on: June 05, 2014, 08:15:59 PM »
Definitely check lug bolts. Lost two days of planting time trying to find a squeak in the rear of a tractor.
Sounded more like an axle bearing. Pulled the dual, didn't notice any shiny spots. Pulled the inner tire, pulled the taper lock hub. Found a 10 foot 4 inch piece of pipe to slide over the axle for leverage, could not make the axle wiggle, seal was still good, ergo not a bearing. Wire wheeled everything till shiny and reassembled. Hooked back up to mounted bean planter, squeak was back. Pulled just the dual and aired the inside tire up, no squeak. Reinstalled the dual, then used the one inch impact to run the dual bolts down, no squeak for a day then it was back.
Rim and hub was a aftermarket unit, just loose enough where the rim fits over the hub for the tiniest amount of movement, not even enough to shine anything up but enough to make noise. Uses regular grade 8 fine threaded one inch bolts with big flat washers instead of a standard lug bolt with a taper. Pulled the dual back off, applied quick metal to the hub boss where the rim is supposed to ride, then bought special cupped washers that would dig a little into the rim, ran em all back on with the one inch impact, no squeak as of yet.
Re: Kubota tractor
« Reply #5 on: June 06, 2014, 06:32:28 PM »
It was the lug nuts,  Phew   easy fix
Re: Kubota tractor
« Reply #6 on: June 07, 2014, 04:53:11 AM »
Glad to know it was nothing expensive but a simple fix.  Roger
