Author Topic: home made water heater exchanger  (Read 9853 times)
butchtn
« on: April 08, 2010, 06:15:44 AM »
i am looking for plans or info and pics to build a water heater exchanger thanks
butchtn
Re: home made water heater exchanger
« Reply #1 on: April 08, 2010, 05:33:06 PM »
i made what you might call a swimmingn pool heater for my domestic water...50 foot coil of 1/2 inch copper inside a pipe. my OWB water flows through the pipe and the domestic water through the 1/2 inch copper. a couple of valves to bypass the water heater and when the OWB is running i shut the breaker off for the hot water tank I guess you could say i have "on demand" hot water. as long as there is wood in the stove i have hot water
butchtn
« Reply #2 on: April 09, 2010, 05:07:06 AM »
thanks a million for the reply how did you go about putting the copper inside the pipe i am assuming that it was apex pipe  got any pics s
thanks butchtn
« Reply #3 on: April 09, 2010, 07:26:52 PM »
thanks butchtn
i used soft copper and wrapped it around an 6 inch pipe, when i let it go it sprung out to about 8 inches and i put it inside a 12 inch. i used copper fittings to screw into the tank and converted to 1/2 inch and drilled the little stops out so i could slid the fitting over the pipe..then soldered them and away i welnt (after welding in the ends..and adding the OWB feed and return)
give the link a try
http://outdoorwoodfurnaceinfo.com/forum/MGalleryItem.php?id=9
markc
  • coalman 400,000 stoker,coal,pellets,biomass
« Reply #4 on: April 14, 2010, 07:12:31 AM »
check out the water to water heat exchanger in the cataloque on my web page it works very good and priced right page 15, model gef-2 ,90,000 btu/ hr  $ 334.00
http://www.outdoorstokerboilersofky.com/contact.html
markc. coalman 400,000 stoker boiler
once you burnt black you never go back
