Author Topic: Glycol or Antifreeze  (Read 48020 times)
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
Re: Glycol or Antifreeze
« Reply #15 on: August 07, 2014, 03:19:59 PM »
Glycol can become corrosive after a few years. Is there any treatment to run with it?
« Reply #16 on: August 07, 2014, 04:01:52 PM »
Check it regularly, 2-3 years and add when neccesary!
« Reply #17 on: August 08, 2014, 06:27:35 AM »
Yes water does transfer heat better and is easier to pumps; but it also tends to start freezing about 32f  ::)
Where as your "typical" 50:50 mix of Propylene glycol you can still pump the fluid down to about 5f, and burst protection to about -20f THESE ARE ESTIMATED FLUID TEMPERATURE, NOT OUTDOOR TEMPS
userdk
  • OWF Model: G 400
« Reply #18 on: August 08, 2014, 04:38:49 PM »
Keep your pump going and don't worry about glycol.
« Reply #19 on: August 08, 2014, 05:25:32 PM »
Standing or still water freezes at 32, the water temp has to  be a lot lower than 32 before lets say a drainage ditch or creek freezes.
« Reply #20 on: August 08, 2014, 05:27:39 PM »
I agree, out of all the units I have put in I don't think there are more than 6-8 that run any anti freeze, set it up to drain the boiler and blow out the lines right from the start and you will be fine.
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #21 on: February 03, 2017, 11:47:12 PM »
I know this post is old but incase anyone reads this wondering about what they do if they leave town.  I run my furnace in the house as I would if I didn't have a wood stove. Set my thermostat to 60 degrees and run my pump on low speed. My water temp in my wood stove stays 90-100 degrees even when it is 0 degrees Fahrenheit outside.  Keep the pump running and enjoy your time away.
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
Goat Herder
  • OWF Brand: WOODMASTER
  • OWF Model: HEAVY DUTY 4400
« Reply #22 on: February 14, 2017, 05:50:33 AM »
I think my temp drops more, a good safety check might be to turn the boiler fan off on a day that we are home and temps are at a level of concern and monitor water temps.  This would tell us how the boiler and other heat systems interact.
We are having the warmest February that I can remember.
aarmga
  • Central Wisconsin
« Reply #23 on: February 14, 2017, 11:00:39 AM »
Same here! Going to be in the 50s this weekend and 60s Monday! Going to get some wood cut.
Stihl 211 - 16"
JD 1025r with FEL
