Author Topic: plate heat exchanger size  (Read 15974 times)
Re: plate heat exchanger size
« Reply #15 on: September 09, 2014, 08:13:20 PM »
The calculations on the BTU's per foot can vary dramatically without a real drawing of how the floor was laid out, also the heat the slab will dramatically change from how the insulation is done, most folks insulate under the slab and skip the sides, the sides are where the majority of your heat is lost, some guys say as much as 80% of the heat loss on an uninsulated slab is lost horizontally to the frost outside.
Steinacher Sales
« Reply #16 on: September 10, 2014, 08:39:51 AM »
dirtdigger,
I guess I would wonder first if your Outdoor furnace is big enough to handle more load on it. If it is I would mount a heat exchanger with fan (air handler) up high out of the way and blow down in the room. You can put this on a in-line thermostat and just plug it in if you have a receptacle close!
This would help you recover after the door is opened too.
Greg Steinacher
618-401-0726
www.midwestoutdoorfurnace.com
dirtdigger
  • OWF Brand: wooddoctor
  • OWF Model: extra large
« Reply #17 on: September 10, 2014, 09:38:02 AM »
Been around a few that didn't insulate very well around the foundation, in the dead of winter with below zero temps the grass was green and growing outside the building.    Mine we insulated to the hill, both under, around and there's a foot of fiberglass blowin in the walls, we've done heat gun temps of the wall and surrounding area's, all are like they are supposed to be behind the insulation and the wall itself.
I've considered a forced air radiator style setup for quick recovery, but with the house already online  I'm not thinking my wood boiler can do anymore, but this winter should tell us more.    We've considered a chip boiler to go along with a wood boiler, but for the costs associated with them all, its looking doubtful.   I'd probably opt for a larger firewood boiler that would be new and keep processing firewood.
We're also getting setup for lp gas in case this winter is another repeat of last winter, to aid us out in times of extreme cold and if or when the wood boiler won't keep up.
« Reply #18 on: September 10, 2014, 09:50:23 AM »
Dirtdigger, I have the exact stove that you do, I now use it for backup only when away from home doing shows with the chip boiler, I am telling you that your issue is not the boiler, you may have a problem with the blower but the boiler WILL do the job, your problem is in the install, may I ask what you ran for pipe, size and have you ever checked heat loss on it? I would love to put you into our chip boiler but it will do the same thing as your Wood Doctor if the pipe is junk!
dirtdigger
« Reply #19 on: September 10, 2014, 05:19:33 PM »
My outdoor boiler is maybe 50 feet from the shop, we put the foam insulated two one inch pex in a four inch tile buried to the shop, there is no bends, elbows or anything in the line, we buried the same type of line to the house, which is 150 feet from the boiler.    In the shop it goes into the plate heat exchanger and back out again, there are two elbows in the plate heat exchanger on the shop side to the water heater, nothing but straight in and out on the boiler side, there is a pump on the back of the boiler that pumps to the shop, another pump does the house.
When we've done the heat loss with a temp gun, maybe not accurate enough, but the temps were close, less than five degree's from the boiler to the house, and less than that to the shop.
We are in a wet area of the state, I installed drain tile a foot deeper than the boiler lines, and some more tile shallower than the lines, the lines themselves are at the six foot depth, mainly because its what the angle it took to get under the shop footings with the bend radius, and the same at the boiler.     As for the brand, I'm not remembering right off, but its the same as everyone in the area has used no matter the brand of boiler installed, all the plumbers and boiler sales people get the same brand, I know I asked at the time.
I should have gone with a larger line, but if we'd do a radiator with a fan to add a faster recovery when we open the door, I'd run another line still for that unit alone with another pump to run it.
« Reply #20 on: September 11, 2014, 06:02:08 AM »
It sounds like you have done it all correctly, can you tell us actual inside pipe size on the underground pipe as well as what you are using for circulators and how they are oriented, pictures will help a lot.
dirtdigger
« Reply #21 on: September 11, 2014, 06:37:04 AM »
Pipe size is once inch pex, pictures I'll have to have the kids attempt that this weekend, that's out of my league completely, I can type on the computer and that's about it.   I'll caliper the fittings and pipe to get you the exact measurements.
« Reply #22 on: September 11, 2014, 06:42:12 AM »
Thank you, I just can't believe the boiler is the issue, mine has done an awesome job heating my uninsulated shop and 3000 foot home for so many years!
dirtdigger
« Reply #23 on: September 14, 2014, 11:18:06 AM »
I was wrong, there is a 90 degree elbow in the line from the shop the furnace, its viable in the photo if they come up on here.
dirtdigger
« Reply #24 on: September 14, 2014, 11:24:25 AM »
Wrong still again, two per line, one in the shop and another by the furnace, the first photo's show the shop and plate exchanger that's not been cleaned off since we foamed the walls a couple weeks ago, the line coming up into the shop is now behind the tin and insulation of the office break room.
I haven't calipered the line but I'm sure its one inch pex, we got the fittings at Menards and some from the place we got the insulated line from.
I'd have to check the model number on the pumps, but they are all three speed pumpgs, gruntfos is the brand, might not have spelled it right, but close enough.
