Author Topic: Uponor Ecoflex  (Read 8045 times)
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Uponor Ecoflex
« on: September 20, 2014, 08:45:14 AM »
Anyone ever used this stuff?
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
Re: Uponor Ecoflex
« Reply #1 on: September 20, 2014, 10:17:06 PM »
I am guessing it is way out of the price range for most OWB's.
It looks similar to Watts R-Flex and ComfortPro Microflex. Those run around $12 per foot for 1" and I think they are a lot cheaper than the Ecoflex.
Jwood
Re: Uponor Ecoflex
« Reply #2 on: September 20, 2014, 11:17:36 PM »
These prices are crazy expensive, you can't even find Logstor around here all of the dealers that used to carry it switched to Rehau now.
Stihl MS 270c
Stihl MS 461
Re: Uponor Ecoflex
« Reply #3 on: September 23, 2014, 07:04:26 AM »
I have it installed at my place; I also have the distinction of having a close family member work for Uponor   :thumbup:
..so I really did not have a choice when in came to which PEX to put in  ;)
Jwood
Re: Uponor Ecoflex
« Reply #4 on: September 23, 2014, 08:17:26 AM »
How does it perform Littlejohn? What did you pay per ft?
Stihl MS 270c
Stihl MS 461
Re: Uponor Ecoflex
« Reply #5 on: September 23, 2014, 01:17:41 PM »
I have 2 runs; 50' of 1" ThermalTwin (to detached garage/shop) & a 85' run of 1.25" ThermalTwin (to house)
...I can't remember the exact price I paid, cause I got all the tubing, fittings, ecoflex and controls in one monster purchase, back in 2010 or 2011.  All told, I could have brought a bright shiny new truck, of a fancy heating system.  Wife likes the warm floors, so I think I made the right choice (for now)
I could not tell you what I run for a delta T thru the pipes, but I have had no complaints other than that week it was -40f, garage had a hard time keeping up (found out later, pump for that side of HX was set to low, next winter I set to medium)
But like everyother pre-insluated pipe, its not fun to wrestle into the trench; even though I dug it all in before pouring concrete
Jwood
Re: Uponor Ecoflex
« Reply #6 on: September 23, 2014, 01:39:41 PM »
What kind of temp drop do you have from your boiler to the house?
Stihl MS 270c
Stihl MS 461
Re: Uponor Ecoflex
« Reply #7 on: September 24, 2014, 07:27:01 AM »
Like I said before I can't tell you what kind of delta T, I have from the boiler, because I do not have any gauges; but this winter I will be investigating.
Also, I only run my pump between the OWB and a FPHX, when there is a call for heat; then I mix water temperature down before it goes out to the floor.  So I am actually controlling how much heat I put out to the floor, by limiting the delta T that the loops in the floor see.
I do know that the 1" pipes to the garage run at about 3 gpm, or thats at least what my pump says its doing.
