Author Topic: induction fan blower  (Read 12082 times)
ironwood
« on: September 20, 2010, 11:06:52 AM »
Anyone tried running an AquaTherm with either a rheostat to slow the induction motor speed or just the trap door for air?  Seems that one could burn less wood that way.
Re: induction fan blower
« Reply #1 on: September 20, 2010, 01:30:07 PM »
Aqua-Therm user here..Never thought to try to slow the fan down or anything.. I dont know any furnace that has fan speeds..Just pump speeds..How much you burn in a season?
« Reply #2 on: September 20, 2010, 07:40:31 PM »
i have never seen one of these stoves u p close...does the trap door determine how much air gets blown in or how much air is let in when the fan is off (to keep the fire from going out?)
parkinspot
« Reply #3 on: September 21, 2010, 05:29:56 AM »
An AC motor speed controller like this should do the trick.
http://www.amazon.com/Electronics-Variable-Speed-Control-K177-1002/dp/B000F9B712
« Reply #4 on: September 21, 2010, 06:05:17 PM »
willieG no air is let in until the fan turns on.. There is a lower baffle under the grates..The baffel stops air at a certain point..Being a furnace user.. Really not sure why you would wanna slow the fan down..
ironwood
« Reply #5 on: September 22, 2010, 08:27:06 AM »
the aquastat opens a flap on the induction fan and energizes the fan.  I wanna know if the flap open would be enough to satisfy aquastat (obviously over a longer timeframe) or slowing down the fan.  Guess I'll have to try it.
« Reply #6 on: September 22, 2010, 01:52:42 PM »
all this type of stuff has been tested by different manufacturers and designers many times.  from what I've read your best efficiency comes from a fan to get the fire going and then close back off.  I would think the longer you keep the fan running whether it be at a low speed or not will just burn more wood.  The more time the flap on your stove stays closed is the less wood you are going to burn if your stove is sealed properly.
« Reply #7 on: September 22, 2010, 05:58:42 PM »
 I agree with Scott7m, everything I have read seems to say that a hot fire burns most efficiently.  I would thing the best thing would be to have a very hot fire and then some down time with very little burning. This of course would depend on how well the furnace is designed to capture the heat that is produced.
« Reply #8 on: September 23, 2010, 07:23:24 PM »
I would think that forced air is more efficient than natural draft..Instant fire..
