Author Topic: opinions on Ranco or Johnson controls thermostats  (Read 13635 times)
jackel440
« on: September 30, 2010, 06:55:20 AM »
I am trying to decide on a controller for my furnace I am building.I am looking at the Johnson. A419.I have seen the Ranco on a few new stoves.has anyone had any problems with either one?
I know I need it to control a fan and an damper actuater.all 120 volts.
Thanks
« Last Edit: September 30, 2010, 06:34:13 PM by jackel440 »
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
jackel440
Re: opinions on Ranco or Johnson controls thermostats
« Reply #1 on: September 30, 2010, 06:36:12 PM »
Well since Willie G is on the ball.I guess I made my first post clear as mud.LOL
I am just wanting to control the boile ritself,and not the inside house furnace.
Just looking for opinions on the 2 different controllers out there.
Thanks guys
New Holland LS170
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
« Reply #2 on: October 02, 2010, 08:28:54 PM »
both are good..
id assume to have a dial style honey well myself, less to go wrong.
Larson88
« Reply #3 on: October 03, 2010, 07:35:41 AM »
 im with scott if your just looking to control the fan and solenoid i would go with a honeywell aquastat there so simple and work really well.
NC4AB
    • Brinkley Electronics
« Reply #4 on: October 03, 2010, 08:08:00 AM »
I upgraded the Honeywell Aquastat to a 2 stage RANCO on my Hardy OWB a couple of years ago and have no complaints.  All the temperatures and differentials are programmable so the Ranco gives you very good flexibilty, and I used the O-10V temperature output to log the water temperature on my PC.
Andy
Hardy H2 (1987)
Stihl 011
Stihl 028
Stihl 039
jackel440
« Reply #5 on: October 03, 2010, 08:12:21 AM »
My plan is to have a standard style honeywell aquastat as my high limit switch for my stove.I will then let the digital controller run the stove the rest of the time.I am designing in a back up system to stop a runaway stove or any other problems that may arise.
I like the finer tuning and control that a digtal unit will provide thats why I am asking.
I do agree with you that Simple is great.I just can't leave well enough alone. :bash:
New Holland LS170
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
jackel440
« Reply #6 on: October 03, 2010, 08:14:55 AM »
Cool I like the idea of logging the water temp on the computer!You could really see what it's doing while your away.
How did you do that?What kind of cable did you run out to the boiler to feed the signal to the computer?I never thought of that.I will have to incorporate this into my stove I think.
New Holland LS170
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
NC4AB
« Reply #7 on: October 03, 2010, 11:25:10 AM »
Don't want to hijack the thread but I use a USB labjack to scale the 0-10v to a usable signal, and I also log the status of the circulation pump, damper, fan and water fill valve.
I set the RANCO to open the damper if the water drops below 160 and closes when the water gets above 170.  If the natural draft is not enough then fan will on when the water gets to 150 and turns of at 160.
I used a thermostat wire to bring the 0-10v signal back to the LabJAck, the digital signals are on a cat 5 cable
A screen shot is shown below:
« Last Edit: October 03, 2010, 11:32:03 AM by NC4AB »
Andy
Hardy H2 (1987)
Stihl 011
Stihl 028
Stihl 039
jackel440
« Reply #8 on: October 03, 2010, 05:34:06 PM »
Hi-jack away it's my thread anyways.That data logging is really cool.I would really like to get some more info on how you did that.Maybe you could be persaded to do a thread and some pics of your setup?
I would like to do that.
New Holland LS170
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
