Author Topic: what size heat exchanger  (Read 10232 times)
flashpnt
  • OWF Brand: ozark
  • OWF Model: econo 2000
« on: October 13, 2014, 10:16:32 AM »
heating a 900 square foot add on what size ex-changer will do it ?  will 12x18 cover it ?
Using water to air .
Steinacher Sales
Re: what size heat exchanger
« Reply #1 on: October 14, 2014, 12:40:30 PM »
Flash,
Your just wanting to heat the 900 sq. ft? A 12 x 18 is 90,000 btu at 180 degree water! Where are you located? If it is well insulated you should be able to heat that with 20 to 30,000 btu's!
Greg Steinacher
618-401-0726
bajonesy77
  • OWF Brand: Prosteel
  • OWF Model: 200
« Reply #2 on: October 14, 2014, 07:33:58 PM »
It's easiest to buy an exchanger to fill up the space it will be placed in. To put a smaller one you will have to force the air thru a smaller area then designed which is not recommended, too many btu's will not not hurt anything, the fan will run less with too large an exchanger just don't go to small. 8)
Brave 22 ton splitter
Stihl 440 magnum 20" bar
Stihl 390 20" bar
ffbare
  • OWF Brand: ridgewood
« Reply #3 on: October 14, 2014, 08:05:39 PM »
I have an 18 x 18 I haven't had any cold weather yet but the heat coming from the ducts are hotter than my furnace ever had.   :post: I agree more btus the better, you fan will run less
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
« Reply #4 on: October 14, 2014, 08:24:12 PM »
That's correct sizing is not critical like sizing a condensing furnace.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
« Reply #5 on: October 15, 2014, 06:31:10 AM »
Yah, but the less the fan runs the more chances of warm and cool spots in a room, longer fan times help to even the heat out in a room. We have a guy that seems to do about everybody's AC and heating in the area, if he's running his AC or heat he puts the fan in manual mode and leaves it run 24/7.
Jwood
« Reply #6 on: October 15, 2014, 08:03:47 AM »
Mlappin is correct all I'm saying is that if you go to big it won't hurt anything except like mlappin said you might have cold and hot spots.
Stihl MS 270c
Stihl MS 461
flashpnt
  • OWF Brand: ozark
« Reply #7 on: October 16, 2014, 06:30:04 AM »
Ok thanks for reply's, 12 x 18 fits the duck so a little overkill but thats ok.
« Reply #8 on: October 16, 2014, 06:40:25 AM »
Use caution when ordering as they typically size by rad size and the frame is about an inch wider than the rad, specify outside dimension needed!
Jwood
« Reply #9 on: October 16, 2014, 06:50:41 AM »
 :post: Slim!
Stihl MS 270c
Stihl MS 461
