Author Topic: help with my setup  (Read 7639 times)
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
help with my setup
« on: October 15, 2014, 09:10:11 PM »
This is a rough sketch of how I want to route my plumbing, now I need everyones help on valves, Wye strainers pumps and placement stuff like that thanks guys!
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
Re: help with my setup
« Reply #1 on: October 16, 2014, 04:00:00 AM »
First get rid of the air vent, they are meant for pressurized systems and are problematic in a non pressurized system,  they can and will allow air back into the system when circs are off when installed above the water level of the wood boiler. Ball valves and unions on both ports of the water to air heat exchanger allow for easy removal and cleaning. Side arm heater should also have ball valves at both ports on the tank on the domestic water tank, top of heat exchanger should be plumbed into a tee at the pressure relief valve, drain tees should be used here as well for easy cleaning without contaminating the water in your tank. Radiant may need a mixing valve and separate circ on that loop if you are using staple up plates or in slab heat, the only radiant that I know of that can be used without a mixing valve is Ultra Fin and it is used only in under floor bay heating.  How is that for a start?
Jwood
« Reply #2 on: October 16, 2014, 05:34:18 AM »
That's great slim thanks! Now I gotta ask is that how you'd do it or do you have a much better idea, this is all still fairly new to me so I obviously want to do it the best way possible
Stihl MS 270c
Stihl MS 461
« Reply #3 on: October 16, 2014, 05:43:11 AM »
I'll try to draw something a bit later, the boss is on her way out to work and is demanding my attention right now!
Jwood
« Reply #4 on: October 16, 2014, 05:51:35 AM »
 ;D sounds good slim!
Stihl MS 270c
Stihl MS 461
« Reply #5 on: October 16, 2014, 06:29:16 AM »
How's this for you my friend
« Reply #6 on: October 16, 2014, 06:41:24 AM »
AND AGAIN SLIM IS AWESOME, but I will add a few NICE TO HAVES
It is also nice if you use isolation flanges on either side of all pumps, makes replacements easier.
About a Wye strainer, I think that those are only required if you have a flat plate heat exchanger (FPHE), so you do not plug it up with sediment and other JUNK, when installing you generally want them as close to the inlet port as is feasible.
2nd the note by SLIM, about using a mixing valve for radiant application.
     NOTE: if you use a mixing valve, it is required to have a pump between the mix device and the radiant manifold.
Don't think slim mentioned it, but I prefer to have all my pumps in the structure that I am heating.  Again there are MANY a threads on best location for a OWB pump, but IMO I do not want to put on all my winter gear to swap out a pump in the middle of the night.   AS LONG AS PUMP at or below the level of water in the OWB you should be good
***Like all the fancy schematics, they always look cleaner on paper   >:D
« Reply #7 on: October 16, 2014, 06:46:14 AM »
Thanks for the kind words LittleJohn, I would welcome us teaming up on an install someday!
Jwood
« Reply #8 on: October 16, 2014, 06:49:37 AM »
Thanks Slim and little John! Slim I will have to call you one of these days I've just been so busy and the days are getting so short now!
Stihl MS 270c
Stihl MS 461
« Reply #9 on: October 16, 2014, 06:51:48 AM »
Take your time and do it right the first time, you won't be sorry, as always I'll welcome your call!
Jwood
« Reply #10 on: October 16, 2014, 06:56:32 AM »
I will have to change the location of the furnace next year, I will be putting it in the basement I believe or buying a new one most likely just for backup obviously! Again that will be a next year project.
Stihl MS 270c
Stihl MS 461
Jwood
« Reply #11 on: October 16, 2014, 07:21:31 AM »
Another question I have is the size of pipe should I just run 1" throughout?
Stihl MS 270c
Stihl MS 461
« Reply #12 on: October 16, 2014, 07:23:11 AM »
1 inch main will be fine but I would use long radius (refrigeration) 90's
