Pages: 1 [2] 3
Author Topic: Help with system-Not Getting good amount of heat  (Read 17764 times)
Re: Help with system-Not Getting good amount of heat
« Reply #15 on: October 20, 2014, 06:03:45 PM »
What do you mean gutted? are you saying that there used to be a circ running constant, keeping the gas boiler hot, if so put the circ back on line and your issue is solved
« Reply #16 on: October 21, 2014, 05:04:12 AM »
Where in your original drawing?
« Reply #17 on: October 21, 2014, 07:59:36 AM »
I can't tell what it was doing from the picture, could you draw it into your first drawing and re post
« Reply #18 on: October 21, 2014, 11:07:43 AM »
That would work but if you put the circ back in, it will also work and that will be a heck of a lot less work, look at your original drawing, your zone circs were pulling through the gas boiler and very little water was forced through your plate exchanger, that is what the abandoned circ was for!
« Reply #19 on: October 21, 2014, 11:53:53 AM »
It should not ghost flow but if it does then lets work on the wiring then! lets get your heat going first!
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
« Reply #20 on: October 21, 2014, 06:22:11 PM »
 :post: :post: :post:  beers to slim!!  what a helper!!
« Reply #21 on: October 22, 2014, 03:46:42 AM »
So is it working?
« Reply #22 on: October 22, 2014, 08:24:51 AM »
I think you will find that it will !
« Reply #23 on: October 26, 2014, 06:34:33 AM »
I gather that no news is good news!
rsv101
  • OWF Brand: Johnson
  • OWF Model: Little John
« Reply #24 on: November 08, 2014, 06:21:37 PM »
It did not seem to make a noticeable difference with the extra pump in place. Not sure what to do.
« Reply #25 on: November 09, 2014, 03:00:44 AM »
OK , now after reviewing your original drawing and first post, I see your wood boiler water is entering the plate exchanger at 160 degrees,This is not hot enough to satisfy your heating demand, baseboard heat needs to have 180 degrees minimum to function properly. Please turn up the temp on the wood boiler to at least 180, next are you sure of the direction of flow in the plate exchanger as it is wrong in the drawing, all plate exchangers should be plumbed with counter current flow, this means if your wood boiler water is entering in the bottom of the plate exchanger then the oil boiler water should enter at the top, this will help with the transfer of heat! Is the wood boiler water being supplied to the heat exchanger from the top of the boiler or bottom, hottest water in the wood boiler will be at the top, if you are pulling from the bottom of your wood boiler, this would be an easy fix to simply reverse the circulator on the wood boiler, is the circ at the wood boiler or inside at the heat exchanger?
rsv101
« Reply #26 on: November 10, 2014, 02:48:04 PM »
The circ is inside at the heat exchanger. The hot line from outdoor wood boiler comes into bottom left of heat exchanger. The hot line on the oil boiler is on the top right side of the exchanger. My hot line on the back of the outdoor wood furnace is at the top. So it looks like my house side is backwards going in and out of the plate heat exchanger?
« Reply #27 on: November 10, 2014, 04:08:45 PM »
When you say hot line on the oil boiler, follow it back to the boiler is it coming from the bottom or top and which way is the circ pumping?
« Reply #28 on: November 11, 2014, 07:47:42 AM »
Reverse your circ on the oil boiler!
rsv101
« Reply #29 on: November 11, 2014, 06:52:26 PM »
Or are you suggesting I reverse only the wrap around circ pump and leave the other two alone?
Pages: 1 [2] 3
