Author Topic: Creosote drip  (Read 10848 times)
Creosote drip
« on: October 03, 2010, 07:16:08 PM »
Anyone ever have creosote drip out around the door seal?  It's not gettin air around it but black creosote drips some.
Re: Creosote drip
« Reply #1 on: October 04, 2010, 10:17:44 AM »
 Is it on a NC stove? Normally any dripping problems are solved by running the furnace harder to burn up the creosote.
Re: Creosote drip
« Reply #2 on: October 04, 2010, 12:40:23 PM »
yep on an NC, i figured out what it was.   I'm burning at a really low temperature of 150..   It's doing great but I through in a couple pieces of green wood and it caused some creosote.  But last night I went back to seasoned wood and the dripping stopped.
Re: Creosote drip
« Reply #3 on: October 04, 2010, 05:53:09 PM »
I have found that the best way to burn green wood is to keep the temp up around 180.
Re: Creosote drip
« Reply #4 on: October 04, 2010, 06:14:52 PM »
Yup, I will agree with that..  If its green wood you had better run your temperature on up in that range.
Most all of my wood is well seasoned.  I still have it set on 150 and its performing flawlessly on dry wood.
Re: Creosote drip
« Reply #5 on: October 05, 2010, 06:55:09 AM »
 I normally run mine at 150 or 160 until it starts getting cold and then I bump it up a bit. I always like feeling really hot heat coming out the vents when its cold outside.
Re: Creosote drip
« Reply #6 on: October 05, 2010, 06:48:20 PM »
Yea...  I have a little laser gun and the air heats the inside of my register to 112-115 right now.   I'm hoping that with seasoned wood I wont have to go over 160-165 this winter.  At least that is the plan
MattyNH
  • OWF Model: 7300E ; S-275
Re: Creosote drip
« Reply #7 on: October 05, 2010, 07:41:31 PM »
Yeah Ive had a creosote drip..Seems like it was cause by buring green or wet wood during warmer temps..Had to replace the door gasket..
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
